Throttle Bodies - Holley vs MSD Atomic
Old Oct 28, 2022 | 11:38 AM
FCar2000TA's Avatar
Veteran: Air Force
Default Throttle Bodies - Holley vs MSD Atomic
Does anyone have any experience with Holley EFI throttle bodies or MSD Atomic throttle bodies?
Old Nov 3, 2022 | 01:26 AM
91 Z28's Avatar
No experience with those but I've got a beauty Motion Raceworks Icon 102 TB. Really nice piece and can be customized with different front attachments
Attached Thumbnails Throttle Bodies - Holley vs MSD Atomic-pxl_20211025_185338653.jpg   Throttle Bodies - Holley vs MSD Atomic-pxl_20211025_185352554.jpg   Throttle Bodies - Holley vs MSD Atomic-pxl_20211025_185023232.jpg   Throttle Bodies - Holley vs MSD Atomic-pxl_20211025_185651058.jpg   Throttle Bodies - Holley vs MSD Atomic-pxl_20211025_192506329.jpg
Throttle Bodies - Holley vs MSD Atomic-pxl_20211025_185422729.jpg   Throttle Bodies - Holley vs MSD Atomic-pxl_20211025_185430030.jpg   Throttle Bodies - Holley vs MSD Atomic-pxl_20211025_192511636.jpg   Throttle Bodies - Holley vs MSD Atomic-pxl_20211025_220056283.jpg
Old Nov 3, 2022 | 10:08 AM
gagliano7's Avatar
I used the warr throttle body and it was a very nice piece and easy to tune.
Old Nov 3, 2022 | 05:11 PM
jasons69chevelle's Avatar
I used a 102 Summit and made a few modifications to get it dialed in. It has that low speed ramp that’s very nice. Used GM sensors
the Summit looks identical to the Holley
Old Nov 4, 2022 | 07:42 AM
Rich-L79's Avatar
I tried a very cheap Chinese knockoff copy of the Holley EFI and it was a raging POS. Don't buy one of those! I would suspect the Holley would be of better quality and have better tolerances but I have no personal experience. My tuner said he likes to avoid Holley TBs for what that's worth.
I went with a Nick Williams and it worked great.
Old Nov 4, 2022 | 09:45 AM
Sounds like the WARR and Nick Williams TB's get the vote around here.
Old Nov 6, 2022 | 11:36 AM
Alwhite00's Avatar
Do any of them not whistle on startup?
Old Nov 6, 2022 | 01:20 PM
91 Z28's Avatar
Mine doesn't
Old Nov 6, 2022 | 10:08 PM
Rich-L79's Avatar
The whistle is likely audible if you have a low restriction intake system. If you have a stock or stock-ish intake, it is likely muffling the whistling sound. Even a stock TB will make a whistle or whooshing sound. Like on a carbureted car, take the air cleaner off and you'll definitely hear an air whooshing or whistling sound as the air enters the carb. Same is true of a TB, but most intake systems muffle the sound with restrictive intake pipes with bends, thick metal or plastic and a muffled air box housing the filter.
Old Nov 10, 2022 | 10:23 AM
gagliano7's Avatar
No whistle on my Warr.
