Super quick starting LS?
Old Nov 29, 2022 | 02:24 PM
RPM WS6's Avatar
LS1Tech Administrator
Community Influencer
Originally Posted by Rich-L79
The biggest downside to carbed engines is if they sit for a period of time (weeks, months, etc.) they required a certain amount of cranking to refill the fuel bowls on the carb.
Correct, but I'm not entirely sure this is a "downside". That extra cranking to fill the fuel bowl(s) is normally enough to circulate oil into places that haven't seen any in quite some time if the engine has been sitting for weeks/months, so I don't really see this as a problem - especially for a non-daily driver (which is likely the case if the car ever sits that long in the first place).
I assume this would be different with an electric fuel pump? I've never used a carb with anything but a mechanical pump, which obviously requires engine revolution to build pressure. When an e-pump is used with a carb, I imagine the bowls are filled immediately during "key-on" (unless operated separately with a switch)? Of course, the accelerator pump would still need manual operation prior to cranking if you want the engine to start (cold).
Originally Posted by TheWrathofDan
tune your gto better, or better battery. it should start faster. but not a big deal
It could probably be possible to start a bit faster than shown in the video but, for all the reasons already mentioned, it will never fire as quick as a carb'ed + distributor setup that's up to temp and running well.
Old Nov 29, 2022 | 02:33 PM
Rich-L79's Avatar
Fair point.
Old Nov 29, 2022 | 02:37 PM
Rich-L79's Avatar
This is funny. You see it sitting on the dyno? It was tuned. If you like, skip forward to about 1:12 where it was started again with a few more tweaks to the tune (now with exhaust and not open headers), same thing, it cranks a bit before it starts. Always has. My 04/LS1 does the same thing, even cranks just a little longer than the LS2 does. Same thing when they were stock, same thing after they were tuned.
Old Dec 6, 2022 | 12:38 PM
TrendSetter's Avatar
wire up a small nitrous kit to the starter signal. instant starts.
Old Dec 6, 2022 | 01:56 PM
Exactly what is the downside to cranking a few turns before lighting off??
I'm seeing much ado about next to zip here...
Old Dec 7, 2022 | 07:11 PM
LS1Formulation's Avatar
Funny you say that... I have a buddy who years ago had a 406 small block in a mud truck that needed a shot of nitrous to start, and let me tell you, it started QUICK! This engine also had 6" AND 5.7" rods due to it being pieced together from a couple blown up engines... The crazy things we did back then
Old Dec 8, 2022 | 01:35 PM
LLLosingit's Avatar
How would N2O be needed to make it start? Not only that it doesn't work in a cold engine, It has to see temps above 500 degrees before the magic happens.
Old Dec 9, 2022 | 12:22 PM
I know how nitrous functions, lol. All I know is what I saw... crank crank crank, a few sputters, hit the button and zoom, came to life. Maybe it was the fuel side helping out. Still was funny to watch.
 Michael S. Palmer
Old Dec 10, 2022 | 11:59 AM
wannafbody's Avatar
People tend to view things in a black or white manner. Ebony interior is one of those issues.
Old Dec 16, 2022 | 03:46 PM
RONIN LSX's Avatar
With my 02 (factory LS1), if it heard my keys jingling, it would practically start, lol... half crank was all it needed, but after I dropped the engine, to do a rear main, and some freshen ups, now the first turn of the key acts like a primer and then the second fires it up. I miss the quick start
Old Dec 16, 2022 | 04:03 PM
Kawboom's Avatar
Y'all DONT KNOW DO YA?
The reason you hear FOUR compression strokes when you crank a MODERN V8 EFI ENGINE is because you have a CAM SENSOR and CRANK POSITION SENSOR, the first FULL REVOLUTION of the engine there is NO FUEL COMING OUT OF YOUR INJECTORS while the computer counts hits and maps the position of where the engine parts are relative to each other. THEN it gives you fuel on the FIFTH compression stroke. It has to do this because as we all know the cam spins half as fast as the crank so it needs a full rotation of the crank to determine where everything is.
An old engine with a carburetor and distributor would have fuel and spark on the FIRST COMPRESSION STROKE, only needs to turn half turn or less to start.
If you had one of the cams with 4 notches on its position sensor, technically you can get it to fire a hair sooner on the starter, but that's something I have no personal experience with.
One thing to know is that if you have a heavy flywheel or a big automatic transmission torque converter bolted onto your engine, that can slow the cranking. I swapped my old mustang to a light clutch and it cranks a lot faster, but still needs a full revolution of the engine to fire.
Old Dec 16, 2022 | 05:02 PM
  #32
RPM WS6's Avatar
The issue seems to be that some folks just haven't experienced the difference (i.e. limited/no experience with well tuned carb'ed/dist. engines and how quickly they can restart when hot) therefore, to them, an SEFI LS1 is as "quick starting" as it can get.
In other words, one doesn't know what one doesn't know.
Old Dec 16, 2022 | 08:04 PM
  #33
smokeshow's Avatar
Lol, I actually had to cal out these instant starts at Chrysler. Or moreso the symptom that causes that instant start in older engines. The reason is the availability of fuel vapor waiting in the manifold. As mentioned below, crank sync is needed before injection on modern EFI, but only for start consistency reasons. Customers like being able to expect the same exact start, everywhere, every time. Fuel from a hot carb application (or in my case, a highly active purge system) prior to shutdown allows for fuel to be in cylinder at the first closing of an intake valve after you hit the key for a hot restart. Produces a nice quick start.....sometimes. Too much or too little fuel though, and start consistency is affected, making a customer bring the car to the dealer with a complaint. EFI fixes that by the nature of having controlled fuel delivery, but also by delaying injection until some calibratable condition...typically a desired cranking RPM when warm.
If you're dying for a super fast hot restart with EFI, find a way to keep that evap solenoid open after you shut the engine down. Might have some mixed results though lol
Old Dec 16, 2022 | 08:55 PM
  #34
99 Black Bird T/A's Avatar
Yes, a previously cranked/warmed up properly tuned carb'd engine will "insta-start" as OP mentioned with a mild bump of the key 🔑. My 72 Vette did with the Lars tuned Q-jet & the current Demon. If the carb'd car's sat for a week or it's cold that initial start won't be an "insta-start" in my experience.
However, running around town making a half dozen stops, it is pretty cool how "intuitive" the good carb car starts...almost like the car responds enthusiastically to your will with a bump rather than a turn & hold key, spin & then crank.
Overall, I much prefer the EFI start experiance overall, especially on colder days if a car has sat for a month...but on a sweer summer day, making a lot of stops and brief trips...there's charm to a good carb'd set up.
Old Dec 16, 2022 | 09:18 PM
  #35
Rich-L79's Avatar
.....almost like the car responds enthusiastically to your will with a bump rather than a turn & hold key, spin & then crank.
Actually I can't speak for ALL LS vehicles, but on the GTOs you don't have to hold the key until it starts. Just turn the key briefly to START and let go. It will crank by itself until it starts. If it happens to not fire, it will stop cranking by itself after a few seconds of cranking (or you can turn the key off to stop it manually).
I assume this is the case too for many if not all other LS vehicles.
Old Dec 16, 2022 | 10:32 PM
  #36
I've turn & hold key on pretty much everything lol
Interesting, I'll have to try turn and let go on my 02 Z28.
Old Dec 17, 2022 | 07:56 AM
  #37
BigBlackCamaro's Avatar
Dodge calls that tip start, I have one that does that and after driving it a few days I get in something else and try to start it the same way. I can tell from accidentally trying that my LS vehicles don't have it.
Old Dec 17, 2022 | 01:52 PM
  #38
RPM WS6's Avatar
Agreed. None of my LS1 4th gen F-bodies came with this feature.
Old Dec 17, 2022 | 02:23 PM
  #39
QwkTrip's Avatar
LS1 F-body can't do an automated crank. The B+ side of the start relay field coil is literally hard-wired to the Start position of the key switch. The relay cannot operate without key switch in Start position.
The BCM (Body Control Module) controls the B- side of the field coil and it can interrupt the starter relay for the security system, but it cannot energize the relay on its own to do an automated crank.
Old Dec 18, 2022 | 05:07 PM
  #40
wannafbody's Avatar
People who talk about fast firing carbs must not have experienced vapor lock.
