Help with LS1 Water Pump part numbers.
Does anyone know if they are the same but with a different number or is there an actual difference?
Thanks
Are you sure it's part number 12681179?
There's a GM part number 12681174 water pump.
The casting number on a part isn't always the same as the part number based on what's in the link. Example GM part number 12681186 water pump has casting No. 12681180 and the casting number & part number don't match.
What vehicle is the water pump for?
Sorry, I'm not much help with sorting out the question at hand.
