Idle goes up and down.
Old Dec 15, 2022 | 05:48 PM
Z Prime's Avatar
Default Idle goes up and down.
Okay I have a 99 z28 m6. I have a problem where the car will drop at idle when the car is at at stop to about 500 rpms. It will almost stall put when I start to go. Then when I am going about 60 mph and put the car in neutral and it will stay at 1500 rpms until I almost come to a complete stop. When im on the interstate sometimes the car will buck for a split second and then go back to normal. I have 2 SES codes. 1 for EGR, but I took that off. And MAP sensor circuitry. I hate dealing with electrical so I don't know where to begin with the circuitry. But could it be the MAP sensor? I just changed it out.
Checked fuel pressure it is at 62 psi.
I just changed the battery, alternator, MAP sensor and fuel filter. Here is a list of other parts I've changed in the past 2 years.
TPS IAVfuel injectorsoil pressure sensorknock sensorsintake gasketsspark plugsspark plug wiresTick performance Master cylinderslave cylindercoil packs
Old Dec 15, 2022 | 06:22 PM
DUSTYWS6's Avatar
I would check all vacuum lines and their connections.
Old Dec 15, 2022 | 09:22 PM
99 Black Bird T/A's Avatar
Might also want to check the PCV hoses especially the one that goes towards the back of the intake manifold. Mine split where it went around to the back.
