Coolant bypass/crossover lines do I need?
Old Jan 23, 2009 | 08:43 AM
Gen414's Avatar
Default Coolant bypass/crossover lines do I need?
OK guys, as most know, I am in the middle of my 414" 6.0 L92 headed build. Do, I HAVE to have the coolant crossover line? Can I plug it off? The car is not a DD, but will see the street. If I do need it, don't they make 2 versions of it? I have not found too much info on it, other than most info I have come across says I need it, but does not say why? So, if I do need it, where can I pick it up, and if there are 2 versions, which one should I run, and if I don't need it, what caps/plugs/kit you guys using?
Old Jan 23, 2009 | 09:19 AM
LS1-450's Avatar
Yes, you need it. It vents to the coolant to ensure that the coolant reaches the highest point on the heads & doesn't get blocked by an air pocket. I would connect both, the rears together, the fronts together & then tie the rears to the front & run the line to the top of the radiator or highest radiator hose. Some will claim that the rears aren't needed. I'm not of that opinion. The rears are near the hottest two pistons, 7 & 8.
Part numbers; Sorry, I don't know, but am sure that a search for GM part numbers will reveal what is needed. If not, you can run the lines w/pipe nipples & fuel line hose if stock looks aren't important (this is how mine is done).
Old Jan 23, 2009 | 09:30 AM
Gen414's Avatar
Ok, thanks. I will do a search and see if I can come up with the part numbers for teh fittings. Stock looks are of no importance to me, especially since the car is carb'd among other things
Old Jan 23, 2009 | 09:40 AM
ramairJP's Avatar
The crossover tube (LS6) is P/N 12568478 and the plugs are P/N 12562788. I'm also not a big fan of plugs in the back two cylinders and would at least prefer two crossover tubes. To connect the nipple off the front crossover tube to the radiator nipple you need 5/16" hose. If you run that crossover in the back (instead of plugs) you'll have to block off the nipple by capping, crushing & welding, etc.
Old Jan 23, 2009 | 09:41 AM
405HP_Z06's Avatar
Agree 100%, you need them. Here are the part numbers :
12602548 Coolant crossover pipe LS3
12602540 Coolant Caps (need 2 if your going to block off the rear)
11588714 Coolant pipe/cap bolts (need 4 or buy M6 x 1.0 x 30mm bolts from a local source)
12551933 Coolant Seals, Head (need 4)
or you can buy these from Wegner and plumb your own lines:
Water Line Adapter
WA0214
GM GEN III/IV LS
Bolt on aluminum slug. Seals to the head with 'O' ring. Has 1/8" NPT female thread. Used to connect water steam lines or to block off water passages on LS engines.
http://s41657.sites80.storefront-hos...l.aspx?ID=3289
Old Jan 23, 2009 | 09:53 AM
Schwanke Engines's Avatar
LS1TECH Sponsor
I have a takeoff LS1 style for $30. It has the four corner steam holes and exits out the front right above the water pump.
Old Jan 23, 2009 | 01:50 PM
Gen414's Avatar
OK guys, thanks for teh part #'s and helpful info. This is my first LSx build, and I am getting close to the end (being finished) and trying to tie up all the loose ends. Schwanke, I will look into the parts and pricing, and get back with ya. Thanks for the offer!!
Old Jan 24, 2009 | 06:31 AM
Gen414's Avatar
Originally Posted by ramairJP
The crossover tube (LS6) is P/N 12568478 and the plugs are P/N 12562788. .
I tried those parts numbers, but they could not be found?
Old Jan 24, 2009 | 06:32 AM
Gen414's Avatar
Water Line Adapter
WA0214
GM GEN III/IV LS
I was able to locate those parts parts, again, THANKS!!!
Old Jan 24, 2009 | 10:47 AM
405HP_Z06's Avatar
These are discontinued part numbers, don't worry about it.
No prob, happy to help.
Old Jan 24, 2009 | 02:00 PM
TopFlite's Avatar
Subscribing for information...
Old Jan 24, 2009 | 03:38 PM
Gen414's Avatar
OK, looks like I am all set up on parts and such, thanks again.
Now, I do have a couple questions again on WHY I need them. You guys are saying to eliminate any air pockets in the system, correct? Why do the Gen III/IV heads have this problem that the Gen I/II stuff don't?
Old Jan 24, 2009 | 03:43 PM
405HP_Z06's Avatar
They had the problem also, it just wasn't addressed.
Old Jan 24, 2009 | 03:48 PM
Gen414's Avatar
Ok, what you are saying then is they found out that the earlier Gen I/II stuff developed hot spots in teh heads, but they felt they could leave it alone? and tehn starting with a clean sheet (Gen III/IV) they would address it?
Old Jan 24, 2009 | 03:50 PM
405HP_Z06's Avatar
Are you saying use a crossover tube in the rear but don't connect it to anything?
Most that use 2 crossover tubes connect them together at the radiator connection hose. The thought being that water would circulate from the rear like the front and hopefully reduce the temperature of the rear two cylinders.
Old Jan 24, 2009 | 03:59 PM
405HP_Z06's Avatar
If you look at some of the hardcore Gen I circle track engines, they use many custom steam lines and other techniques in an attempt to keep the heads evenly cooled.
In the Gen II engine they introduced reverse cooling in order to address this issue. They also used a single air bleed on the thermostat housing to release trapped air from the system.
Old Jan 25, 2009 | 08:51 AM
Gen414's Avatar
Yeah, I was aware of the Gen II reverse cooling (just sold my 97 WS6). I guess what I am saying is, are they REALLY needed? I mean, if I installed a bleeder in the upper hose, wouldnt that do the same trick as teh bypass line? My wife's Jeep GC 4.7HO has teh bleeder valve on the tsat housing on the upper hose. Isn't that basically serving the same purpose, or am I missing something else?
Old Jan 25, 2009 | 11:05 AM
LS1-450's Avatar
Sounds like you're trying to talk yourself out if of it. So, do it "because we said so." J/K
Even if you bleed it properly, there is an added benefit (some dissagree) to the added & unrestricted circulation of coolant from the front & rear ports (tied together) & into the the radiator. The other advantage is when the owner lets the coolant level get low (not low enough for an CEL fault), the heads have some cooling from the coolant that manages to find its' way further up the heads because of the avenue created by the rear line that is connected to the fronts & the radiator.
Old Jan 25, 2009 | 12:52 PM
405HP_Z06's Avatar
Exactly what I was going to say. Agree^^^^^^^
Old Jan 27, 2009 | 08:15 AM
Gen414's Avatar
OK, guys, THAT was what I was missing. Thanks! I figured I was missing soemthing for the sake of, if it wasn't REALLY needed, why is everyone for the most part, still using it. So, i figured there was SOMETHING that I was missing.
Thanks guys!
