View Poll Results: What's gonna be quieter and least raspy
Y pipe into single muffler and tailpipe
5
71.43%
True Dual
2
28.57%
Dual muffler into y pipe and tailpipe
0
0%
something else
0
0%
Voters: 7. You may not vote on this poll
Duals vs Duals into y vs single
Old Apr 19, 2023 | 04:50 PM
Jacob VH's Avatar
Default Duals vs Duals into y vs single
can't find any answer to my question so thought I'd ask here
my motor should be around 450whp. it's almost done and I'm working on building the exhaust
​​​​​​I've got 1 3/4 headers, 3" high flow cats, and an X pipe.
I'm runing 3" duals definitely halfway down the car. Then I'll either run a 3" to 3.5/4" y pipe into a single 4" muffler, dual 3" mufflers into dual tips, or dual 3" muffler into 3.5"/4" y to tailpipe
Does anyone have experience with these sorta different setups? I know all of them should have no problem with supporting the hp I'm making. Just wondering what's gonna be quieter, less raspy?
Thanks
Old Apr 19, 2023 | 09:02 PM
wlink14's Avatar
I run a true straight pipe, no cats and no mufflers, with 3" y pipe to a 3" single single out the back. It is very loud, but I like it.
From my limited experience a single exhaust with the right muffler will make the car more manageable and less raspy with more "throatiness". Since you have cats it already wont be as loud.
I personally do not think you need any larger than a 3.5" single exhaust. My mild 6.0 (380-400whp) pulls cleanly to 6800 with the single 3",
Old Apr 20, 2023 | 05:38 PM
Jacob VH's Avatar
I'll probably just do an axle dump and figure out what i like. 3" dual muffler, then throw a y pipe and decide based on that. I bought the truck straight-piped but it was way too loud. Didn't make the family happy leaving early in the morning so I threw on an areo turbine 3030xl. It seems most people are saying to go with a single muffler.
What's done to the 6L you got?
Old Apr 20, 2023 | 08:19 PM
LS1 TJ's Avatar
On my 98 Wrangler LS6 swap so around 425 HP? I'm running 2.5" from the left to the right side header into a 2.5" to 3" merge and then 3" all the way to the rear bumper. Largest Dyno Max turbo muffler I could fit. Good sound as I hit the road. Zero drone at speed.
Old Apr 21, 2023 | 01:48 PM
RPM WS6's Avatar
LS1Tech Administrator
Community Influencer
Rasp (at least as I define it, meaning the Kazoo on crack sound) will not be an issue if you plan to use cats, regardless of the rest of the exhaust. But any Y-pipe arrangement will always be more prone to rasp than true duals.
I don't personally like how cats tend to mellow and smooth the exhaust note so my preference would be to delete them and stick with true duals (which will not rasp if you use mufflers that offer at least "mid-grade" sound reduction). I'm not a fan of the X-pipe arrangement as it also tends to smooth (and raise the pitch of) the exhaust note - but you might prefer this if mellow/quiet is the goal. I don't really see the benefit of doing an X-pipe and then a Y-pipe afterwards though; if you're going to do the X then I would just keep it as true dual from there...just add hi-flow mufflers to suit your (volume, sound) taste.
Old Apr 21, 2023 | 07:56 PM
Jacob VH's Avatar
That's what I'll probably do. I got the 3030xl on the truck, I bought a second one, we'll see how it goes
Old Apr 28, 2023 | 10:01 PM
B4CMaro's Avatar
I did the speed engineering dumped duals and cut back the pipe going into the bullet mufflers. Put an offset inlet center out borla 4x9 on both ends and it is pretty mild. I think this is a good balance of weight, cost and sound. Doesn't drone on the freeway.
