04 Silverado Maf issues
Old Jul 14, 2023 | 01:48 PM
Kfx450r's Avatar
Default 04 Silverado Maf issues
I have a 2004 Silverado that has a lq4 with hci and a 100 shot of nitrous. I was messing with the intake a little bit and damaged one of the maf resistors by accident. Went and bought a new ac delco unit and truck bogs with black smoke at 4k rpm. Ran great with original maf. One thing I noticed was the resistor colors in the original one had blue ones and the new one had grey ones. Any help is greatly appreciated I really want to get this thing back on the road. Don’t mind the ghetto soldier on the one side I tried to see if I could soldier it back together.
Old Jul 14, 2023 | 04:33 PM
SoCalDave's Avatar
Get a used part from your local junkyard or Ebay. Should be good after that.
Old Jul 14, 2023 | 04:49 PM
Kfx450r's Avatar
I’ve tried one off of my other 5.3 truck with no success.
Old Jul 14, 2023 | 06:28 PM
Kfx450r's Avatar
Bump.
Old Jul 14, 2023 | 08:27 PM
slothman's Avatar
maybe double check the part numbers? if a new MAF didn't fix the issue I would suspect other issues with the motor.
Old Jul 14, 2023 | 10:36 PM
Kfx450r's Avatar
I appreciate the response. It ran great with the other maf I broke by accident though. If it had problems with the engine wouldn’t it be a present all the time?
Old Jul 15, 2023 | 09:53 AM
Kfx450r's Avatar
Anyone?
Old Jul 15, 2023 | 11:14 AM
slothman's Avatar
So the car is tuned right, because you have a cam etc ? Black smoke means running heavy rich. I believe once you install a new MAF you have to get the car tuned again. I could be wrong but maybe talk to a tuner.
Old Jul 15, 2023 | 11:17 AM
Kfx450r's Avatar
Yes it was tuned by the mustang shop in Kent Wa. I really hope that’s not the case because they are out of business.
Old Jul 15, 2023 | 11:42 AM
slothman's Avatar
that's no issue really, any good shop can tune it. do you have a handheld programmer ? I am fairly certain the car needs to be re-tuned because of the new MAF. In other words, your old broken MAF was specifically tuned for your cam. Now the car is dumping fuel and running rich. You could ask a performance shop or tuner, they will know what to do.
Old Jul 15, 2023 | 11:50 AM
Kfx450r's Avatar
I’ll ask around. Up here in Alaska theirs no reputable tuner from what I’ve gathered. I’m kinda wondering if the mustang shop put different resistors in this particular maf to read richer? I saw a post on here about something like that.
Old Jul 15, 2023 | 12:01 PM
slothman's Avatar
the resistor idea is a possibility but who knows. If there are no tuners in your area, you could always get a mail order tune from a reputable company.
Old Jul 15, 2023 | 12:10 PM
Tommy42088's Avatar
Did you break the housing on the old sensor? Maybe trying using the new housing and removing the old sensor and put it on the new housing
Old Jul 15, 2023 | 12:17 PM
Kfx450r's Avatar
I’ll see if I can get it apart. Thank you
Old Jul 15, 2023 | 01:04 PM
Kfx450r's Avatar
I’m gonna bring it to a computer repair store and see if they can soldier different resistors on the new one. Thank you for all the responses I’ll post if it fixed it or not.
Old Jul 15, 2023 | 03:12 PM
Kfx450r's Avatar
I just pulled one of the blue resistors off of the old broken maf and tested it with a multimeter. I only got 23.8 ohms?
Old Jul 15, 2023 | 08:32 PM
slothman's Avatar
I believe ohm resistance is around 2.0-3.0
https://autoditex.com/page/mass-air-...-maf-19-1.html
Old Jul 15, 2023 | 09:43 PM
Kfx450r's Avatar
I’m gonna have to wait until Monday for an electronic store to open. One thing I was wondering is if the c5 z06 maf runs leaner than the truck maf or if they’re the same?
Old Jul 16, 2023 | 07:26 PM
slothman's Avatar
the issue is, you have a custom motor, with cams, exhaust, heads, etc. Therefore, you can't use a "stock" MAF with calibration. The MAF that was broken , was probably tuned specifically for your current motor and cams. Therefore any "regular" MAF is not going to work well, without some tuning. So, you either A) fix the MAF that was broken or B) tune a new performance MAF for your motor at the dyno shop or have a custom tune emailed. The current mods will determine which MAF you need to purchase. I am not sure which one you need. Honestly at this point I would go with the second option. You can jack up a motor REAL fast if it isn't tuned right. And it sounds like you have a decently modded motor. You should also gather any receipts and lists of mods, so you can find out which MAF you need, and so your tuner knows what he is dealing with. It is very possible the MAF you are using is completely wrong for the mods that you have. JMO
Old Jul 17, 2023 | 11:11 AM
Kfx450r's Avatar
Thank you slothman, I do highly appreciate it. I’m trying to get in contact with the original dyno tuner in regards to this. I’m not driving it until this gets resolved.
