Mechman Alt pics
Old Jul 29, 2023 | 12:47 AM
sjsingle1's Avatar
Default Mechman Alt pics
Old Jul 29, 2023 | 12:48 AM
sjsingle1's Avatar
sjsingle1's Avatar
Old Jul 29, 2023 | 12:49 AM
sjsingle1's Avatar
sjsingle1's Avatar
Old Jul 29, 2023 | 12:50 AM
sjsingle1's Avatar
this harness that comes with the alt is a must....I first thought I did not need it....boy was I wrong
Old Jul 29, 2023 | 12:53 AM
sjsingle1's Avatar
sjsingle1's Avatar
Old Jul 29, 2023 | 12:54 AM
sjsingle1's Avatar
the alt needs a switched 12v source....used the 4 chan abs fuse spot
sjsingle1's Avatar
of course you need the BIG 3.....used 1 gauge wire to pos and neg....the alt has a mounting bolt on the front of the alt for the neg ground point
Old Jul 29, 2023 | 12:55 AM
sjsingle1's Avatar
14.77 volts all day long !!!
Old Jul 29, 2023 | 01:05 AM
sjsingle1's Avatar
the plug connection is at the bottom of the alt....I first extended the wire with a new plug with longer wire....the check gauges light on the dash came on..could not figure it out.....called mechman and thats when i found out I needed the H104 wire harness....install that wire harness and the dash light goes off
Old Jul 29, 2023 | 09:38 PM
GMRL's Avatar
Interesting....Ive had the battery light on after installing random aftermarket alts in various cars. I wonder if running an additional 12v switch wire like that would of remedied it.
Old Jul 30, 2023 | 03:06 AM
sjsingle1's Avatar
i dont understand why it works.....but it does
Old Aug 10, 2023 | 09:02 PM
Second_Infinity's Avatar
Oh heck yes. I've had that stupid light on for several years and hadn't been able to sort it - and was way past any warranty on my Mechman.
