Lq4 intake manifold suggestions and help
1: which intake would be best suited for my application? Fast 102, msd atomic, btr equalizer, fast 92, anything else?
2: what all will be needed to make the intake work with the car? For example, the fast 102 seems to require an ls2 fuel rail kit and then I’m not sure what else would be needed. Does the ls2 kit work with all factory lines? Are adapters needed? Would it just require ls2 style injectors?
3: what would be the best intake that is easiest to swap in? It seems the consensus is the fast 102 isn’t worth all the extra work required to fit it.
im not overly familiar with ls engines so any help is appreciated.
If you want to lose power below 5k RPM, use a sheet metal short runner intake. In other words, don't.
The FAST and MSD manifolds cost a fortune, will gain SOME power, but at what cost?
What people don't realize is that most LS engines come with decent intakes and heads for most uses. Just put in the cam that gets the power you want and done, usually.
