Fast 102mm PCV Tube Removal
Might be a dumb question, i have a 102mm fast throttle body and was wondering if the hardline for the pcv can be removed or how to plug it. Gonna be running -10an from each valve cover to a catch can.
I believe it's a press fit and it can either be removed and then tapped and threaded for NPT to AN or you can cut some of it off or just leave as is and place a rubber hose end cap on it.
The following users liked this post:
ohhhlogi (04-07-2024)
Good looking build you got there.. I'm in for an idle clip.
