04 LQ4 starter issues
Old Jul 29, 2024 | 06:00 PM
PJBOZ's Avatar
Angry 04 LQ4 starter issues
I have a 6.0l bored and stroked on a run stand fitech ultimate FIF-71007 and holley mid mount accessory drive. I put a high torque starter on it and starter engages but won't disengage.Anybody else have a problem like this
Old Jul 29, 2024 | 08:12 PM
the_merv's Avatar
How is it wired up?
Old Jul 29, 2024 | 11:34 PM
Full Power's Avatar
The 8 mm solenoid stud goes direct to battery Positive.
The 5 mm terminal gets (momentary ) positive 12 volts from start relay- Takes a pretty stiff amp pulse to engage, if battery voltage is low, or IF main positive feed to the 8 mm stud is undersized, or corroded, the solenoid can attempt to draw even MORE amps than normal, and CAN weld the starter relay contacts together. I suspect your test stand battery and/or wiring is insufficient.
Old Jul 30, 2024 | 04:46 AM
PJBOZ's Avatar
Originally Posted by the_merv
How is it wired up?
exactly as you stated,I tried a different starter got the same results.I will try a new battery later to see if it changes.
Old Jul 30, 2024 | 05:00 AM
the_merv's Avatar
That wasn't me but have at it..
Old Jul 30, 2024 | 04:36 PM
PJBOZ's Avatar
My starter issue seems to be alinement problem it engages the flex plate and rotates the motor but only disengages half way.tried shims but still gets stuck
