LSXRT 102 & TFS 235 alignment issues
416 with the deck cleaned up .003
TFS 235 milled .060
felpro .041 HG
Anyway im trying to get this lower part of the manifold to line up with the ports. Im thinking with the engine decked, milled heads and thinner HG the manifold doesn't want to sit down all the way on the intake ports of the heads. One side will but the other side hangs up on the ledge right by the edge of the manifold.
Doesnt sit flush here
Port lines up pretty well considering some ive seen posted here. Right side of manifold could use some blending.
Has anyone used a fel pro intake gasket between the head and manifold to help? Either that or I'm going to grind down the edge of the manifold on both sides that are cloarst to the valve covers.
What are your thoughts?
My LSXR didn’t line up well to my 235’s. I ended up port matching the heads removed some material and added some also.
I ended up grinding most of the ribbing on the underside of the lower manifold down as it was still hitting the valley cover. I also rounded over the furthest edge closest to the valve cover to allow the manifold to sit flush against the intake surface of the cylinder head. Almost done.
now the engine is making a very loud whistling noise at medium throttle above 3000 rpms. Almost like its sucking air in somewhere. I tried carb cleaner around injector ports and all around intake. All vacuum ports are capped off and zip tied to insure they can't come off.
Siliconed the runners to the lower manifold. Then siliconed the upper to the lower. If its got a gasket or seal or vacuum port its getting siliconed. Ill probably silicone the manifold to the heads also.
