LQ4 low oil pressure
Old Sep 19, 2024 | 10:58 AM
alex6.0's Avatar
Default LQ4 low oil pressure
Hey all,
Fresh build, 6.0 lq4, ls3 heads, vs 85/102 turbo, big 264 cam.
Oil pressure was good on first start. 44psi idle, went up to 50ish with small rev.
Took it out for first drive and noticed oil pressure had dropped to between 10 and 20 when I got back. Plugged the turbo feed line and saw 40psi cold at idle. Could this be a flow or too low pressure oil pump? Replaced with OEM GM pump and same issue.
Old Sep 19, 2024 | 12:08 PM
Full Power's Avatar
GM Dashboard "Indicator" or a known accurate GAUGE ?
when you saw the drop to indicated 10 PSI was that HOT, with break-in oil ?
Possible that you have a lot of fuel dilution from initial tune ?
How big ( inside diameter) is oil feed line to turbo ? I've heard reference to using oil feed restrictors in Turbo feed ..
Old Sep 19, 2024 | 12:33 PM
alex6.0's Avatar
Drop to 10 was with hot break in oil. Tune AFRs were pretty good. Plugs werent wet. Same symptoms with fresh oil as well. Starts at 40, drops to 20 and doesnt really increase much with rpm.
We are using a journal bearing turbo and from what I have read they dont need a restrictor. Motor is coming out this weekend to drop the pan. Its in a 87 GN with solid non-removable cross member
Old Sep 19, 2024 | 07:43 PM
the_merv's Avatar
Veteran: Air Force
Could be the Sensor, a bad one does that when they get hot.
Old Sep 23, 2024 | 07:20 PM
jetech's Avatar
Veteran: Air Force
Originally Posted by alex6.0
Hey all,
Fresh build? Does this mean new bearings and quality machine work OR used short block with cam and heads?
