2002 t/a p0300
Old Sep 23, 2024 | 08:02 AM
blue04vert's Avatar
Default 2002 t/a p0300
I know this issue is discussed a lot. But I wanted to list my specific issue and see if anyone has any ideas.
At cold start up, car idles fine. Once warm it starts to miss fire at idle. Does not seem to miss fire when driving at higher RPMs.
Spark plugs look good.
no vacuum leaks that I can find.
ill be checking fuel pressure later today however seems to me if it was a fuel pump issue it would miss all the time??
originally the code was a P0302. So I swapped coils to the other side and a P0300 came up. Want to check the code again but so far hasn't thrown a code a 3rd time.....but definitely still misses once warm.
ill report back once I check fuel pressure.
Old Sep 23, 2024 | 11:24 AM
Rich-L79's Avatar
Bad spark plug wires or perhaps one or more of them are poorly connected.
I recently installed brand new plug wires and was getting random misfires. One plug wire was repeatedly falling off the plug. I replaced that one wire and the problem was resolved.
Old Sep 23, 2024 | 04:08 PM
blue04vert's Avatar
I tested the coil on that cylinder and it's good to go.
all plug wires are definitely on firmly.
I guess next I'll swap all the plugs and wires. I HATE throwing parts at something. It gets expensive in a hurry.
Old Sep 23, 2024 | 05:55 PM
the_merv's Avatar
Possibly the Crank Sensor on the way out. If I had that problem I'd put a scanner or something of that nature on it to see what everything is doing. TPS voltage, IAC position, etc..
Old Sep 23, 2024 | 06:01 PM
blue04vert's Avatar
yeah im gonna have to set that up with someone for sure. just checked fuel pressure and its holding nice and steady at 57/58 PSI at idle and still missing.
ughhhhh
Old Sep 23, 2024 | 07:50 PM
the_merv's Avatar
I wouldn't be putting any new parts on it until you datalog it and see what's going on.
Old Sep 30, 2024 | 01:20 PM
blue04vert's Avatar
so with a more in depth scan its specifically #2 and #6 that is missing.
The guy really didn't know enough to tell me more than that. hard to imagine what would cause those 2 specific cylinders to all of a sudden start missing. Im frustrated and not sure I have any options other than taking it to the dealer at this point and I REALLY hate to do that.
Old Sep 30, 2024 | 08:30 PM
the_merv's Avatar
Move Coils and see if the misfire moves. I'd move Injectors around also.
