LS1 Misfire
Old Sep 27, 2024 | 07:50 PM
mcoon1987's Avatar
Default LS1 Misfire
So I’ve got a 4a 2001 trans am, stock internals, full bolt on, and recently I’ve been having a misfire issues. My scanner isn’t showing showing anything, so I can’t pin the exact cylinder down. It is showing three O2 codes, it’s been throwing O2 codes for a couple years, but I always just clear them because it’s always ran fine. It has 4 like stock.
The plugs are maybe 2k miles old, NGK TR6, but the wires look original to me. I ordered some MSD plug wires, but I also want to get the O2 sensors. I took one out and it was pretty black and soot covered. It was an AS98 AC Delco, but it seems like they don’t make those any more. The ones I can find they only have 1 or 2 in stock, and they’re extremely expensive, upwards of $90 each.
https://www.amazon.com/gp/product/B000BZG5QC/ref=ox_sc_act_image_1?smid=A1CYKG5KAOLKHH&psc=1
I found these, but some reviews have been spotty. The 13444 looks to be the same with a slightly shorter hook up wire. It looks like I’d need three of the shorter 13444 and one of the ones I put above.
Does anyone have any recommendations for O2 sensors? Could this be causing my misfire issues? And lastly, the back drivers side sensor has the plug in damn near on top of the transmission. Any tips on making that easier to unhook and plug back in?
The plug wires look like they will be fun to get to on the last two on the passenger side, but I will cross that bridge later.
Old Sep 27, 2024 | 09:10 PM
GMRL's Avatar
Worn out 02 sensors can definitely cause it to run rough. You said no misfire codes stored for any specific cylinder?
I wouldn't buy any name brand parts from Amazon or ebay. You can get some Denso ot Delphis from Rockauto for a good price.
Old Sep 28, 2024 | 01:51 PM
mcoon1987's Avatar
https://innova-electronics.helpscout...tem-tests-menu
This is the scan tool I am using. It won’t show any codes for misfire, it’s almost like it doesn’t support the vehicle for that or something. I have no idea why because the other scan functions work. It was throwing P0135 and a couple others.
Good call on not getting Amazon parts. You wouldn’t happen to have any part numbers by chance?
Found the Densos and those have awesome reviews, so I’m gonna go with those, thanks!
How would you disconnect that from the harness? There is no play in the wires, and I can’t even get one hand up there, let alone two to unhook it.
Old Sep 28, 2024 | 08:40 PM
GMRL's Avatar
The Densos are 2344087 for upstream right and 2344025 for upstream left.
That looks like decent scanner, I think it there were any misfire codes stored it would display them for sure.
Thats a tight spot for sure. What you can try maybe, is once you have the new sensors. Cut the wire off from the end of the old sensor while its still threaded in, then maybe use a long screwdriver or pry bar to pop the harness end of the connector from whatever its attached to. That should give you enough slack to let it come lower and then unplug it
Old Sep 29, 2024 | 12:04 AM
mcoon1987's Avatar
I have 4 sensors still. I’m not sure why, had the car for years and all the mods were already done. Long tubes with no cats. The car has a tune, so I want to keep everything exactly how it is. The front two and back drivers have the shorter lead, and the back passenger is slightly longer.
Good idea on cutting the wire first. I’m still worried about getting it plugged back in, and I can’t really tell if that zip tie is just around the wire, or if it’s actually secured to something.
