Rear O2s needs.
Old Nov 18, 2024 | 08:02 PM
the_merv's Avatar
Originally Posted by gametech
For the purposes of this thread you are correct. However, most tuning software does not allow you to disable a background test of the rear o2 sensors. This means that for people who are fine tuning their fueling, there will be what appears to be an unexplained "glitch" in their numbers that comes and goes, even with the rear o2's disabled and removed. This has no practical effect on anything, but it has confused several new tuners.
I've never seen any "glitch" with my HP Tuners. Once I turned off all the codes for the Rear O2's nothing happened.
Old Nov 19, 2024 | 12:06 AM
gametech's Avatar
Active Streak: 30 Days
Active Streak: 60 Days
There is a cat efficiency test of some sort that runs even with the codes turned off. Unless you are very closely analyzing your A/F during the exact time that test is run, you would never notice.
Old Nov 19, 2024 | 07:50 PM
the_merv's Avatar
I watch my wideband more than the laptop but yea next time I datalog something I'll have to see if I notice.
Old Nov 19, 2024 | 11:45 PM
gametech's Avatar
With the exception of the occasional OCD sufferer on the HPT forums, it is a non-issue that has no practical effect on anything.
