Ls swap pcv/catch can routing help
when they put mine on they left the valve cover vented with a filter... im starting to think that wasnt correct bc there is no way for it to pull a vacuum...
(and opening for it sealed off), then from the catch can to after the TB. This way there will be airflow thru the engine. Your diagram does not allow that.
The PCV System needs to make a loop with no vac leaks in it anywhere to work right. I have one on my truck hooked up this exact way and works perfectly, been there for years.
Barb on the Throttle Body is clean metered air into the Engine, that is to the Passengers Valve cover.
Out of the PCV Valve in the Drivers Valve Cover to the Can.
Can to the port on the Intake.
Plug that Filter on top you want the system closed. No Vent.
