Starts then dies
Old May 23, 2025 | 12:09 AM
CobeWS6's Avatar
Default Starts then dies
99 Trans Am. I replaced the fuel pump and fuel filter. Cara starts then dies immediately. Sometimes if I’m quick enough and hit the throttle it will stay running til I let my foot off the throttle. I cleaned the throttle body. No codes. Any help will be apperciated
Old May 23, 2025 | 01:40 AM
gametech's Avatar
Active Streak: 30 Days
Active Streak: 60 Days
The more info you provide, the more help people can give. For example, what caused you to replace the fuel pump and filter, and what were they replaced with?
Old May 23, 2025 | 05:42 AM
DUSTYWS6's Avatar
Did this issue appear after making any changes to the car? Do you have a scan tool to check IAC counts?
Old May 23, 2025 | 06:20 AM
CobeWS6's Avatar
i replaced the fuel pump cause the fuel pump went out, so I went ahead and replaced the filter
Old May 23, 2025 | 06:22 AM
CobeWS6's Avatar
Before I replaced pump/filter it would turn over and not start. After it starts then dies. I don’t have a scanner than can check IAC counts
