PCV Valve?
Old Nov 3, 2025 | 02:56 PM
Skier's Avatar
Default PCV Valve?
i have a 2002 LS1 in my boat. is this the PCV valve or just some plastic connector? I read some had them and some don't. i didn't want to pull on it too hard b/c I heard this how setup is fragile. Engine has 700 hours (probably something like 60,000 miles in car lingo) thought of cleaning or replacing b/c of oil burn. Boat is running a constant 3000 rpm pulling skiers and am burning a quart in 40-50 hours.
Old Nov 3, 2025 | 06:28 PM
01CamaroSSTx's Avatar
Yes, it's inside that circled portion of the line.
Old Nov 3, 2025 | 07:58 PM
Full Power's Avatar
Low hours and heavy oil consumption- I would immediately VENT the crankcase. PCV is NOT helping your cause.
Unless you have California crawling in your ***, there's NO reason to restrict your crankcase vents. I like minimum 1/2" inside diamter OPEN HOSE.
Old Nov 3, 2025 | 08:04 PM
It's in a boat, so no smog....
Old Nov 4, 2025 | 10:45 AM
Skier's Avatar
sounds interesting but not sure that would be safe in a boat? - my engine is under a huge cover.
Old Nov 4, 2025 | 08:20 PM
Just run either -8 or -10 lines off each valve cover to a breather can mounted somewhere to ventilate the fumes outside of the compartment. You could also run a sealed catch can. Just mount it to the passenger cylinder head and connect the line with the PCV to the inlet and from the outlet run a line through your PCV valve and then connect it back to the intake manifold. Breather can would be better if you ask me though.
