Cylinder Head Vent Gasket
Old Dec 19, 2025 | 12:27 PM
grinder11's Avatar
Originally Posted by slowride
The type that only use an o ring also have a groove for the o ring. The older type with the metal embossed o ring will be flat as the gasket takes up the spacing and locates the o ring.
Absolutely. You can't just squeeze the o-ring against a surface that offers no protection against the O-ring being completely flattened. The LS has many "gaskets" like these. The aluminum prevents squeezing the O-ring out of shape. The surfaces "bottom out" against the aluminum rather than the O-ring itself......
Old Dec 19, 2025 | 05:52 PM
wannafbody's Avatar
Can't you just seal it with some Ultra Black?
Old Dec 19, 2025 | 06:15 PM
dixiebandit69's Avatar
Yes, I have done this many times.
Originally Posted by IGN-1A
Yes, what I meant was that I installed a Pipe Plug in the Rear two holes (back of Crancase)
Are you talking about the oil galleries for the lifters?
Old Dec 19, 2025 | 06:20 PM
the_merv's Avatar
Veteran: Air Force
Cheap parts you can buy at O'Reilly's and people use RTV..
