Steam hose plumbing question
Old Dec 7, 2025 | 04:56 PM
patman2's Avatar
Default Steam hose plumbing question
I have a 68 C10 that I bought with a partially completed LS swap. I *think* it is a 4.8 out of a 2004 pickup, gen III LR4. It has an Edelbrock intake and carb, and an MSD LS-series ignition box. I've installed a radiator (probably from the donor truck) and have the two big hoses hooked up. There's no cap/fill on the radiator, so I hit rock auto for an expansion tank that I could mount on the inner fender. The engine has the 4-corner steam vent pipe, and there's a connection about halfway up the RH radiator side tank for that. There's a larger connection near the top of the side tank that goes to the expansion/fill tank. The expansion tank has two vent pipes coming off the top edge, above where the coolant level should be. Currently I have those looped together to plug them.
Question: should I be using those two vent pipes for anything? Like should I connect the steam vent pipe to one, and then go from the other vent pipe to the connection on the side tank?
Old Dec 7, 2025 | 05:02 PM
B52bombardier1's Avatar
Connecting at least one of those steam vents into your coolant system is usually recommended but I don't think you need to use both of them. It helps to have at least one of them connected to purge air and the foamy steam bubbles out of the engine's water jacket. My two LS engines only run one of these lines.
Rick
Old Dec 7, 2025 | 05:24 PM
patman2's Avatar
Right now the steam pipe is connected to the radiator at the lower connection (labeled in picture) Just leaving those vents on the expansion tank looped together (and having the steam pipe connected to the radiator as it is in the picture) makes the most sense to me, but I thought I'd ask.
