Fresh Air feed to Valvecover?
Old May 1, 2026 | 09:25 PM
Tommy42088's Avatar
I think that's a great way to set it up!
More lines just means more room to relieve the crankcase pressure and having it behind the cab IMO is better than inside an engine bay. I can tell you that I when I drain my can it's not oil pouring out, only condensation with some traces of oil but it's only when I drive the car in the colder months otherwise I never have to drain it.
I do have to drain mine every now and then but its never any oil, its always condensation. I always run e85 too though. I was nervous running it back there thinking maybe it would work well but it actually worked out well. I put a valve on the bottom of it with a hose also running through a grommet under the truck so its super easy to drain. Just a matter turning the valve on/off.
