Need help- HEADER INSTALL
Old Aug 2, 2004 | 02:43 PM
99SSinOC's Avatar
Default Need help- HEADER INSTALL
I've got every bolt undone, except that satan bolt... the number 6 back passenger side bolt.. How did you all get it off? I cant get jack on it. any ideas will help me!!! ITS HOLDING UP THE PROJECT .
Thanks,
Garrett
Old Aug 2, 2004 | 02:49 PM
destroyerSS's Avatar
are your coil packs and oil dipstick tube removed??
99SSinOC's Avatar
Coil packs = no, oil dipstick tube, yes (it had to be for bolt number 4)
Old Aug 2, 2004 | 02:50 PM
ddelallata's Avatar
remove the coil packs/rail assembly with a 10mm socket and this allows you to remove the last bolts from the top. A ratcheting wrench from Sears really helps too and should be no more than $8. Again, the key IMO to a smooth install is the removal of the coil packs.
Old Aug 2, 2004 | 02:51 PM
Squintz Palladoris's Avatar
Edit... Doh! passenger side. I usually use a 1/4" drive ratchet or a wrench. It helps to have small hands, smelling like cabbage is optional.
Brad
Just unbolt the coil packs bracket and take them all off in 1 shot
Old Aug 2, 2004 | 02:53 PM
99SSinOC's Avatar
Thanks for your help guys, I'll run out and pull the coil pack off, hopefully it'll work then! I'll keep you all updated, thanks a bunch for the speedy responses!
Old Aug 2, 2004 | 03:47 PM
BLKWS6's Avatar
good luck with the bottom bolt holding the coil pack on...right next to the heater hose.....
Old Aug 2, 2004 | 05:35 PM
99SSinOC's Avatar
Well it's all off now, just trying to get the pass side header in... any ideas on how I can get it up even higher? my jack stands are maxed out =p. Does it go in from the bottom or the top? I bought a new set of stock gaskets, since they said they were the best, correct? Any help would be appreciated .
Old Aug 2, 2004 | 06:31 PM
Long tubes go in from the bottom.
Did you jack the entire car up and put it on 4 jack stands? That will give you a little more height. I have some big stands so I dont have this problem. You can pick them up pretty cheap from Harbor Freight.
Brad
Old Aug 2, 2004 | 09:12 PM
m2002z28's Avatar
I put the car (tires) up on solid cement blocks when i did it. and after the jack couldn't go higher i put it on blocks too. the big jack stands should be enough though. Just be careful. And both headers should go in from the bottom.
