TB Bypass - 1/4" splice ok?
Old Aug 4, 2004 | 02:02 AM
LS1LT1's Avatar
Question TB Bypass - 1/4" splice ok?
I just did my throttle body bypass and I used a 1/4" fitting/splice to put the two coolant lines (one was a slightly larger inner diameter than the other and was a tiny bit loose until I clamped it down) together.
I just want to make sure that I'm not restricting any coolant flow to the heads or anything by using a smaller than 5/16 (or whatever size it should be) fitting.
TIA.
Old Aug 4, 2004 | 03:07 PM
LS1LT1's Avatar
