Question about gauge wiring....
Old Aug 8, 2004 | 01:37 PM
slyws6's Avatar
Default Question about gauge wiring....
Where did you guys tap into your power source for your gauges that is under the hood and not in the drivers side fuse panel? Thanks.
-Sly
Old Aug 8, 2004 | 10:09 PM
01RedZ28's Avatar
-Sly
When i wired my tach i tapped into the orange wire behind the radio and wired everything behind there. Hope this helps not sure what kind of gauge your trying to hook up.
Old Aug 8, 2004 | 10:13 PM
slyws6's Avatar
cool thanx for the reply. I just re-routed to the #2 over and #2 down fuse on the drivers side in the dash. I ran a...(i forget what gauge wire, wired it awhile ago) to all 3 gauges in my a-pillar (boost, a/f ratio, turbo oil pressure). Thanks again.
-Sly
Old Aug 8, 2004 | 10:18 PM
01RedZ28's Avatar
-Sly
No problem
Old Aug 9, 2004 | 01:53 AM
Ferocity02's Avatar
I used the fuse block and "Gauges" fuse. worked well
