Best way to get to #8 spark plug?
Old Aug 8, 2004 | 08:02 PM
Uno99's Avatar
Default Best way to get to #8 spark plug?
Any suggestions on how the remove #8 park plug. I have every other plug changed except #8.
Old Aug 8, 2004 | 08:04 PM
Richie Carbone's Avatar
BADA BING BADA BOOM!!!!!!
Remove the passenger side coil packs and A.I.R. tube. It will give you more room.
Old Aug 8, 2004 | 08:10 PM
U NV SS's Avatar
Jack up car and do it from undernieth.It's the easiest to change if done that way.
Uno99's Avatar
I removed The A.I.R tube But not the coil pack I'll give it a try thx.
Old Aug 8, 2004 | 08:26 PM
LoPeY's Avatar
From below the car is probably the easiest way. I changed all of mine out from below when I installed my headers. It's also a lot easier to hook the plug wires back up from the bottom.
Old Aug 8, 2004 | 08:55 PM
Dustin Butts's Avatar
I always get it from the underneath also. The A4's are a little tougher for some reason at least the few I've worked on.
Old Aug 8, 2004 | 09:00 PM
Cody Brooks's Avatar
don't worry about whole coil pack rail get just the coil pack off cylinder 6 and stick your arm through the hole you just created. Its still a tight squeeze but it works and its faster to remove 2 bolts than the number holding the coil rail on.
Old Aug 8, 2004 | 09:09 PM
furiouSS99's Avatar
Take the coil packs off and jump on top of her missionary style...forget about going underneath, unless you have tiny girl hands.
Old Aug 8, 2004 | 09:28 PM
LoPeY's Avatar
Hay that's pretty weak you Canadian lumberjack! From beneath is the only way to go. I'm half Canadian anyway, my Dad is from about 250 miles east of Winnepeg. Keewatin, Ontario.
Old Aug 8, 2004 | 09:53 PM
furiouSS99's Avatar
So you like to sneak up on things from behind huh? What's the other half of you, Heinz 57?
While your at it, why don't you tell him the best way to change his oil is to siphon it out from the valve covers...
Old Aug 9, 2004 | 02:20 AM
A Mod's Avatar
Default Cracking me up!
You guys are ccrracckking me up.
As for changing the plugs, I guess I won't know if i have little girly hands until I try to change my plugs. Although I think I'll just jump on her missionary style and go for it!!!
Old Aug 9, 2004 | 03:16 AM
OnyxY2KSS's Avatar
get some LT's
Old Aug 9, 2004 | 04:44 AM
UnderCover B4C's Avatar
8 is best done from down under!
Jimbo
Old Aug 9, 2004 | 06:50 AM
pmh's Avatar
pmh
couldn't get to mine from under the car. I guess that means I don't have "girle hands"!
pmh
Old Aug 9, 2004 | 08:56 AM
Uno99's Avatar
I tried late last night from underneath there is no way I can get my hand through there.
Old Aug 9, 2004 | 09:30 AM
Another_User's Avatar
The best way to get to the number 8 plug is to get a super-hot super-flexible gymnast to hang from a trapeze upside down in your engine bay. Naked. Nuff said.
Or you can just move the air tube out of they way, pull all the wires, move the throttle cables to the side, and jam your arm in there and scrape it all up. That's what I do, but if I had a choice I would go with my first plan.
OWENMUSTANG's Avatar
Take the coil pac off along with the air tube...
the "trick" is use a SPARK PLUG SOCKET then put a short socket on the hex part
of the spark plug socket use a 3/8 rachet from the top...
took me 2 or so hrs before i got that tip from here....then 2 minutes..
i didn't see how getting it out from the bottom was preferable w/ stk manifolds
btw my car is a 98 m6
Old Aug 9, 2004 | 11:46 AM
Uno99's Avatar
I like the gymnist part I'll she if my girlfriend is up for a little role playing. I'm going to give it another try this afternoon after work thx for the tips.
Old Aug 9, 2004 | 11:56 AM
01 Red WS6's Avatar
When I did my plug change I did it from up top..Next time I will do it from under the car. When I got under there to do some other work The plug was easy to get to. Which I had done it that way from the beginning
Old Aug 9, 2004 | 02:54 PM
DannoWS6's Avatar
Yup from the top, the bottom is way to narrow. I got big hands and taking off the last bolt for the coil packs is almost as hard as changing the plug.
