ASP pulley question
Old Aug 9, 2004 | 10:23 AM
4u 2 nv's Avatar
Default ASP pulley question
I just installed a ASP underdrive pulley on my car. After driving it i feel a slight vibration at 4000 RPMs only. Not higher or lower just at about 4000 RPMs. also it seems that my OIL pressure has gone up about 3-5lbs on the gauge. now i know that the GM oil gauges or just as vague as the coolant temp gauges. Anybody else have these problems.
On install all i did was remove the old one. lube up the pulley and shaft with oil. bolted it down to bottom out(or 240 ftlbs the intructions said which ever comes first). backed it off like the directions said and torqued it down to 37 ftlbs and then went another 120 degrees. however i couldnt make it another 120 degrees after the 37ftlbs. at about 90-100 degrees i was already clicking my torque wrench which was set for 260 ftlbs so i think that 260 ft lbs is more than tight enough. ugh what should i do now? it looks installed straight and everything so i think im gonna pull it off. send it back and just ask for a new one from New Era Performance!
Old Aug 9, 2004 | 10:58 PM
4u 2 nv's Avatar
Nobody has had any problems with theirs?
Old Aug 10, 2004 | 09:54 AM
01 Red WS6's Avatar
Ive had mine for a little over a month and never had that problem. I did have a problem with the alt. pulley. When it bottomed out it messed up the alt and I had to get a new one and just left the pulley off
Old Aug 10, 2004 | 09:11 PM
MidnightWS6's Avatar
Yes, others have had vibration issues with them. Its rare but it happens. Have them replace that one.
