Swapping 99 LS1 Engine in a 98 T/a
Old Aug 9, 2004 | 05:21 PM
C_B64's Avatar
Default Swapping 99 LS1 Engine in a 98 T/a
Is there anything I should know first. Any connections or any trouble I may encounter. The 99 Engine is out of a z-28 and going into a 98 T/A. Any help would be appreciated. Thanks........
Old Aug 9, 2004 | 06:28 PM
2001CamaroGuy's Avatar
as long as you use all the 98 sensors/wires/exhaust manifolds/etc and just use the long block out of the 99, you won't have any problems. An LS1 is an LS1
Old Aug 9, 2004 | 09:32 PM
WILWAXU's Avatar
Use the injectors and fuel rails from the 98 motor. Bigger injectors
Old Aug 10, 2004 | 07:10 AM
C_B64's Avatar
Thanks guys.
I will use all my sensors then... I have LT headers, and SVO 30lb injectors......
What about the knock sensors, will they need changed.........
Old Aug 10, 2004 | 07:19 AM
Ryan K's Avatar
Pathological Modifier
no, they should be fine.
Ryan K.
