Motor mount tabs, up or down???
King of Pigskin Knowledge
Tabs on motor mounts go up or down when putting on the block? Like over or under the mount on the k-member?
Which motor mounts are you using? I used the Energy Suspension poly mounts and I had to cut off two of the tabs (one on each side of the mount) so the bolts would line up.
