Different Intake designs
How much better are they than the LS1/6 style of intake ??
A friend is building a turbocharged engine form his TR7, and he has made his own inlet from aluminium, with a twin throttle up front.
Im considering this myself. Are there any benefits from such a design ?
I'll also be turbocharging, but not just yet.
Anyway, i can see loads of options, seems to be easy to play around with different throttles too. Well, if you have some space inside the plenum, you can change the length of trumpets, and make the chamber smaller and try out lot's of things to suite your LS1 perfectly... You are not stucked with a permanent design...
How about a divided plenum chamber? There will be only four cylinders per chamber instead of eight, so cylinders are more isolated from each other. This reduces the danger of backfire or cross-firing.
Do you have more info about this plenum??
You could even bolt a Carburettor or 2 on top of the lid instead should the need arise.
At the minute the plenum is just open inside. So there are many options. Trumpet design hasnt yet been decided
I don't like it. That plenum setup with a 90mm TB would be better IMO.
pls, correct me if i'm wrong..
Lastly.. it's not a right or wrong idea. That's why my post said "IMO" Which = In My Opinion.
it is being built right now, I just have to wait a few more weeks
The nice thing about it is they set it up with a ford throttle body for me, so I got a 105mm TB for 300 bucks
https://ls1tech.com/forums/showthrea...etmetal+Intake
