Help,02 sensor circuit high volts?
Old Aug 12, 2004 | 04:54 PM
98Redta's Avatar
Default Help,02 sensor circuit high volts?
This is the code my car is throwing now, I fixed everything else. I thought maybe I had a bad connection since I cut the 02 sensor in half and extended it with some wires so I redid it all the same way, made sure everything was hooked up good and it threw the code again. Whats the deal?
Old Aug 12, 2004 | 05:24 PM
jimmyblue's Avatar
Moderator
Like maybe a heater wire got crossed with the
O2 sense or ground return wire?
I'd say to go check the voltages on the four
wires involved, at the PCM connector, as a start.
Old Aug 12, 2004 | 10:12 PM
wrencher's Avatar
wrencher
Other than what jimmyblue said which is likely..Your not post to splice the wiring on the O2 sensor. It has corrision/heat resistant wiring & doesnt solder or butt connect well at all. You should always use extentions IMO to keep from having problems.
