?'s about true duals
Old Aug 20, 2004 | 06:53 PM
00ls1's Avatar
Possible Scammer - Buyer Beware - Issues Unresolved
Default ?'s about true duals
i was looking into true duals for my 00 T/A. they would be dumped before the axle, i have heard that this may heat up my fuel and cuase problems, is that true???
doug
Old Aug 20, 2004 | 07:42 PM
Z28Venom's Avatar
doug
You're speaking of vapor lock..
If you're running a bullet style muffler then you shouldn't really have to worry about this.
If you're going to run something along the line of a Borla XR-1 or Magnaflow 4x9. They could get pretty close to the fuel lines. I was told to buy the heat reflective aluminum tape (like what's used in the engine bay of the fuel lines) this should prevent any vapor lock issues..
Old Aug 20, 2004 | 07:44 PM
00ls1's Avatar
thanks man, thanks for the link too
Old Aug 20, 2004 | 08:35 PM
BLASTER's Avatar
I used the heat tape from jegs on the lines and I am in the process of building a little heat sheild for my fuel filter. I noticed that it got a little warm the other day. I didn't want to put the tape directly on the filter so I am going to set up a sheild so it can come on and off when it is time to do a filter change. Good Luck
