pacesetters question???
Old Aug 23, 2004 | 08:48 PM
2002$$'s Avatar
Default pacesetters question???
they supplied me w/ everything except sims.should i;1.)use their gaskets or FEL-PRO's? 2.)use their header bolt's or my old ones? 3.)extensions or use their DIY kit?.........................TIA.
Old Aug 23, 2004 | 09:05 PM
Z28Venom's Avatar
1. I would reuse your stockers or buy a replacement set from the dealer.
2. I used the Pacesetter bolts, but you could also reuse your stock ones. It's up to you.
3. Please buy extensions. Don't chance screwing up your O2's.
About the sims. Do you plan on getting an Edit tune anytime soon? If you do, just deal with the SES light until you can get the rear O2's removed with Edit.
Even if you don't plan to get a tune. I would just deal with the SES light.
Old Aug 23, 2004 | 09:08 PM
cyphur's Avatar
i've been drivin w/o egr for like 4k miles now, and i have a 2000. nice yellow SES light on all the ****** time. oh well. you get used to it. hopefully i'll be gettin hptuners sometime in the near future.
Old Aug 23, 2004 | 09:44 PM
2002$$'s Avatar
i already ordered fel-pro gaskets, so ill use those.ill probably use the pacesetter bolts.and about the extensions...thats what i was thinkin,dont F them up.im ordering sims tomorrow,thanks.anything else i need to know?
Old Aug 23, 2004 | 09:52 PM
fasthwks's Avatar
old gaskets, pacesetter bolts, extensions, and simms= easy install
Old Aug 23, 2004 | 10:49 PM
2002$$'s Avatar
why not new gaskets,why OLD?
Old Aug 23, 2004 | 10:51 PM
02WHITEZ's Avatar
i would get a brand new set of gaskets
Old Aug 23, 2004 | 10:57 PM
Z28Venom's Avatar
Because most of the time new gaskets aren't even required. The stock ones are multi-layered metal gaskets.
Very realiable.
 Michael S. Palmer
Old Aug 23, 2004 | 11:00 PM
2002$$'s Avatar
fel pro gaskets arent reliable? i already ordered them,so im just gonna use 'em.
Old Aug 23, 2004 | 11:01 PM
Z28Venom's Avatar
Nah.. that's not what I'm saying at all.. Just telling you what most do.. They either reuse the stock ones or just get a new set from the dealer.
I'm sure that the felpros will work great also..
Old Aug 23, 2004 | 11:11 PM
2002$$'s Avatar
gotcha...i thought you were sayin the stock(used)ones were better than the FP's.i just heard the fp's were very good sealing gaskets, so i got 'em.
Old Aug 23, 2004 | 11:13 PM
2002$$'s Avatar
what does running in open loop mean venom?i know its when your o2's arent hooked up.but what does it make the computer do?
Old Aug 24, 2004 | 08:02 PM
2002$$'s Avatar
well,got my manifolds off today that sucked!!LOL.waiting on degreaser now to clean the sealing surface,before i installthe headers.i just hope i dont have to do any notching to the k-member.i just cant wait for this install to be done!the benefits are more than worth it.
Old Aug 24, 2004 | 08:09 PM
Z28Venom's Avatar
If you have the update version of the Pacesetters, you won't have to worry about notching the k-member.
Old Aug 24, 2004 | 11:11 PM
2002$$'s Avatar
today i got one manifold off today(took drivers side yesterday) the passenger side was hell! and i got the driver's side header in today,went in like a glove.fit is perfect.im really happy with how well it tucks under.they look very nice. thanks for all your help,venom. i cant wait to get my cam now.working on my car is so addicting, its like CRACK!!!
Old Aug 25, 2004 | 02:40 PM
tomaSS's Avatar
Glad to hear that the driver side header did not require notching, cause I'll be in your shoes this weekend if my headers come in! Try buying HP Tuners, to me that is like crack! I have been messing with it for almost a week! There is so much to learn and I still don't know squat! Good luck on the rest of the install! Let us know how it went.
Old Aug 25, 2004 | 06:12 PM
86 IROC's Avatar
I put mine in last night/today... driver's side on my car required me to trim that chunk of aluminum on the driver's side of the engine block. Other than that - slid right in from the bottom.
Old Aug 25, 2004 | 07:12 PM
tomaSS's Avatar
Geez, I was hoping that I did not have to trim anything to put them in. I'll have to wait and see I guess.
Old Aug 25, 2004 | 07:47 PM
2002$$'s Avatar
mine slid right in no problems at all!i finished up today.i had to remove the pass. side heat shield,cuz i didnt want it to make any noise.other than that slid in like butter.you just have to find the right angle and its all good.i used a 13" jack w/ 2- 4x4's on top of it. cant w8 to get o2 extensions and sims(on order, should be here tomorrow)
Old Aug 28, 2004 | 09:25 PM
rally2247's Avatar
Are you driving without o2 extensions and 02 sims?
