I need pictures of TSP True Duals on the car.
Can someone send me pictures of your TSP True Duals installed on your car. I had mine installed today and I think the exhaust shop installed them wrong. I only have about 3 to 3 1/2" between the ground and my bullets. I have Pacesetter Long Tubes and a stock torque arm. Did you have to relocate the fuel lines inorder to get the drivers side up higher? How close did you get it to the torque arm? Any techniques to pass on to the exhaust shop would be more than appreciated? The x-pipe is loacted where the plate went across the car. Should it be closer to the front? I'm taking it back Monday Morning to try and get it higher.
Thanks
Thanks
i got like 5" of clearance w? my fabbed ones.i had 2 have it redone like 2 or 3 times tho.before i just had stock mannys ,now i got it rehooked up to my LT's.looks great.try2get u some pics by tomorrow.good luck.u kinda have to tell the shop exactly how you want it but dont forget u dnt wnt the pipes to be banging your floorboards....
I've done a search. The one with a soda can is not TSP's dual system. I just need to see some better pictures from under the car. I'm pretty sure I need to get it up beside the torque arm. Just would like to have some pictures.
Thanks
Thanks
