catch can install ?....
Old Aug 31, 2004 | 04:13 PM
vals1kid's Avatar
Default catch can install ?....
i am running a procharger and i have an oil problem so i bought a catch can to catch the oil. i have a question on the install... do i run a hose from the top front of the valve cover to the top of the can or does the hose come from the actual pcv valve to the top of the catch can? and then does the other hose that comes off the side of the catch can run to the top of the throttle body or the side of the manifold? thanks guys.
Old Aug 31, 2004 | 04:18 PM
Ravenous T\A's Avatar
Mine is from Pcv-pipe to top of Catch can then bottom of catch can to behind TB (on manifold) pipe
Old Aug 31, 2004 | 05:01 PM
vals1kid's Avatar
and off the valve cover did you run a breather or hook it back up like it was stock?
Old Aug 31, 2004 | 06:20 PM
Z28Venom's Avatar
When I had my catch can:
PCV Valve to catch can... catch can to passenger side of intake manifold.
As far as a breather goes, I believe the guys here were replacing the oil cap with a Metco breather I believe.
I left the little hoses on the passenger side valve cover connected just the way they were.
Old Sep 1, 2004 | 08:49 AM
My Valve covers still have the oil filter cap on it, but then im not Boosted
Old Sep 1, 2004 | 09:01 AM
hourang's Avatar
it goes inline of the pcv hose, remove the hose in between the pcv valve and the tbody, the inlet connects to the pcv valve, outlet connects to the tbody.
Old Sep 1, 2004 | 11:33 AM
Z28Venom's Avatar
No,
It goes inline with the PCV valve and the hose that enters the passenger side of the intake manifold.
Old Sep 1, 2004 | 12:39 PM
hourang's Avatar
Originally Posted by Z28Venom
No,
er yeah intake my bad, it goes over there somewhere, lol.
