What Can It Hurt
Old Sep 2, 2004 | 04:08 PM
blubyeu2000's Avatar
Default What Can It Hurt
I Want To Cap Off The Evap Line For The Fuel To The Throttle Body. I Broke That Damn Plastic Peice. It Keeps Coming Of 'cuase I Rigged It Causing A Vac Leak.
A Will I Lose Any Performance
B What Else Do I Have To Do Besides Cap It Off On Both Ends
C What Was The Point Of It Anyways
Old Sep 3, 2004 | 03:09 PM
anyone
anything???
Old Sep 3, 2004 | 05:26 PM
John_D.'s Avatar
It takes vapors out of the normally pressure sealed gas tank, when the evap solenoid opens, and lets the engine burn them off.
You can replace it with a rubber fuel line. If you want to keep the quick connect fittings, just take a box cutter and lightly cut the nylon tubing lengthwise over the barbs on the fitting, and then the line will split off the fitting, and you can keep the fittings. Find some rubber fuel hose, shove the fittings up in there, and away you go.
Old Sep 3, 2004 | 05:51 PM
Will I Be Hindering Performance In Any Way Letting It Vent All The Time Like That
Old Sep 3, 2004 | 11:21 PM
Hawkcmc's Avatar
You might get a SES light because the gas tank is supposed to be sealed.
CMC
Old Sep 4, 2004 | 10:00 AM
i always have my ses light on. I just dont want to lose any hp because of it always venting.
will I or not?
