stainless
Old Sep 13, 2004 | 11:48 AM
badaSS346's Avatar
Default stainless
Is there the slightest possible chance that a pair of stainless steel headers can rust after being on a car for four months?
Old Sep 13, 2004 | 03:21 PM
jrp's Avatar
jrp
SN95 Director
under severe conditions i suppose and low grade stainless steel. i've seen a pair of rusted SLP's before but the time frame was alot longer then 4 months.
Old Sep 13, 2004 | 07:27 PM
16nrollininaws6's Avatar
Four months and they are stainless? HIGHLY doubtful
Old Sep 13, 2004 | 07:29 PM
ddelallata's Avatar
sounds like some surface rust on some low quality SS
Old Sep 13, 2004 | 07:34 PM
jimmyblue's Avatar
Moderator
There's all kind of stainless and some is more stainless
than others. There are tradeoffs between hardness /
material properties and corrosion resistance. I have a
stainless SLP Y-pipe and it's good and brown. Not
like regular steel crusty brown, just a discoloration.
Especially the hot part of the headers, I would expect
to see blue and straw color after the first heat cycle
and settling into a dull browned look eventually. But
this oxide will be stable and not progress at anything
like the rust rate of mild steel.
Now, you take a wire brush to it and crumbs come off,
that's not stainless.
Some stainless is nonmagnetic and the rest, fairly
weakly magnetic. So you could test by a small magnet,
judging the "stick" relative to body sheet metal.
Old Sep 13, 2004 | 07:36 PM
tonyb's Avatar
Look under a Ford.Thats what all their stainless exhaust does.Just low grade stainless.
