need sum help! does this sound weird?
ok i just installed sum pacesseter LTs and 3 in ORY. i had in there hooker ceramic coated shorties and 2 1/2 in ory. both had no cats.
after installing on dynoed hp stayed same but torque jump 15 rwtq. so i guess my numbers were fine. anywayz. what i was asking is.
i also installed a janzter tb. this was after the dyno. and i thought everything was good. now im **** about alot of things especially my car as i know most of u are. i started driving and ive noticed that the i dont have such a sensitive throttle on the car anymore that to get on it i really got to smash it down to the ground. and also while im driving and after i get on it and let out a little. i hear a lot of kind of little poppy sounds and i can feel them also. is this just cuz i switch to lts. and cuz i got a cutout. and its just a newer sound or should i be worried at all? the sound is just kind of worrying me i cant tell if its a bad sound of a good sound. let me know thanx! -Brendan
Originally Posted by Full-Force
you gained no hp from shorties and 2.5 y pipe to long tubes and 3" y pipe?
Is the popping like a back-fire? Or is it like an exhaust pop? Or is it a leak from the header? Hmm, if you feel them, I hope the cut-out isn't pointing towards the panels
-Todd
