So Cutouts after Collectors are bad... what how about this?
Anyways, would it be safe/equivalent if I put like 12" of pipe on the cutout itself? That way, the open air would be about 14-16" from the O2 sensor. I see no problem with this, but maybe it won't work for some reason. They will be electric so they won't be open all the time, but certainly more than just at the track.
Thanks a lot!
edit: ah, they're electric.....so you could weld the pipe after the actualy cutout.....
If I want performance, I will open them, so I can care less how much power I lose when they are closed.
reduce the reversion of fresh air (but I don't know the
maximum reversion distance). Also if they leak then the
"tail" will be full of fairly-fresh air when closed and the
leak will be near the O2s. So far mine has shown no sign
of any significant leakage but it is way, way back so a
don't-care.
Make the "tails" have a turn-down while you're at it, you
will like the reduction in floorpan "boom" with no loss of
bystander effect.
btw, you might burn up o2s, but i don't think you need to worry about the valves.....
