What is better 2.5'' or 3'' for y-pipe?
Old Sep 23, 2004 | 12:25 PM
LS1SS4ever's Avatar
Question What is better 2.5'' or 3'' for y-pipe?
Is there a difference in gaining power or sounds? What is better for lower car?
Old Sep 23, 2004 | 12:34 PM
LS1LT1's Avatar
Lightbulb
2.5" will obviously be better for a lowered car (takes up less space, more clearance) but as far as which makes more power, just too many factors (engine size, NA or FI, stock internals etc?) to consider there.
Old Sep 23, 2004 | 12:38 PM
Ragtop 99's Avatar
A properly designed 2.5" into 3" (or 3.5") can produce better torque on stock cammed cars because the narrower diameter helps keep the velocity of the exhaust gasses high. On cammed cars shifting 6500 and higher, I would go with 3" into 3.5"
A poorly designed merge will kill a Y-pipe using 2.5" sides
Old Sep 23, 2004 | 03:15 PM
matts22's Avatar
So on a car that plans to have heads and cam in the future, is a 3" y-pipe (like qtp with flowmaster merge) going into a 3" I-pipe with a cutout going to make the most power next to true duals? How much difference is there between a 3" and a 2.5" y-pipe as far as power?
Old Sep 23, 2004 | 05:28 PM
luv2spd's Avatar
Just go with the 3" ORY and get a cutout. Power will be close to true duals especially with the open cutout.
Old Sep 23, 2004 | 06:05 PM
lsx24's Avatar
Correct. That is why you would want to pay for quality headers, or just put something on there if you know you can replace it soon with a quality part. I don't see how the different stepped headers can gain lots of easy hp, that would require some real R&D.
Old Sep 23, 2004 | 07:57 PM
matts22's Avatar
How much power do you lose going through high flow cats compared to an ORY? Because I have heard that without cats, there is rasp with most aftermarket catbacks. And rasp is something that will bug me, so if the power loss through cats is negligable, then I'll just use them.
Old Sep 24, 2004 | 10:46 AM
lsx24's Avatar
It is negligable, 8-12 rwhp on a dyno jet.
Old Sep 25, 2004 | 12:01 PM
AdamSS's Avatar
NO WAY !!! - More like 2-3 rwhp.... It's a sad myth that high-flow cats take away more than that...
Old Sep 25, 2004 | 12:51 PM
LS1LT1's Avatar
Lightbulb
It depends. On an internally stock motor naturally aspirated motor it might be only 3-5 rwhp but on a more serious set up (heads and cam, stroker, blower/turbo etc.) it could be as much as 15-20rwhp in some cases.
And if they rob any less power than that then they probably aren't really 'functioning' cats, more like small bullet mufflers with open screens in them at that point.
Old Sep 25, 2004 | 01:52 PM
matts22's Avatar
Well, I wouldn't really be keeping the cats to be "functioning" as far as emissions. We don't even have emissions testing in Missouri. I just don't want rasp from my exhaust. And I have heard a lot of stories of how bad rasp is without cats. Does the metallic substrate cats make any difference?
Old Sep 26, 2004 | 08:23 AM
Viper's Avatar
You could use bullets where the cats go like i did to remove rasp.
