bbk 80mm th-body worth it over stock ported?
Old Sep 23, 2004 | 04:53 PM
mike c.'s Avatar
Default bbk 80mm th-body worth it over stock ported?
i was thinking of the bbk 80mm th-body. will it give me more power over my stock ported unit? i have a head and camed car. thanks, mike c.
Old Sep 23, 2004 | 05:14 PM
SouthFL.02.SS's Avatar
!LS1 11 Second Club
I think the problem with the 80mm BBK is that despite its larger diameter, the diameter of the intake is smaller than 80mm, therefore you won't have a clean passage for the air to flow through.
Old Sep 23, 2004 | 06:18 PM
Another_User's Avatar
Exactly. It is not worth it. A stock ported one should be fine, unless you want to go all the way up to a LSX 90mm intake and TB combo.
Old Sep 23, 2004 | 07:43 PM
cyphur's Avatar
port your stocker. if you have the patience, you can do a really nice job yourself. take a dremel with a nice conical shaped rounded cutting bit, a few sanding wheels for the dremel, a few sheets of different grit sand paper, and you'll be good to go. putty-form jbweld works really well
Old Sep 24, 2004 | 06:44 PM
mike c.'s Avatar
bauer racing already ported my stock one. i can't use the 90mm because of my t.n.t ring. if my intake is only 75mm,i can't see the point in buying the bbk unit. thanks, mike c.
Old Sep 25, 2004 | 06:12 AM
Larry's Avatar
Unless you are using an aftermarket mass air body a larger throttle body will do little if anything. The stock mass air body has an equivalent flow diameter of a 66 mm bore.
Old Sep 25, 2004 | 09:06 AM
Originally Posted by NoseUpChromeDown
It's not what the unit will flow @ 100% throttle, it's what it'll supply at part throttle compared to the factory unit.
If that is all you are worried about, the safest "mod" would be to push your pedal down further at part-throttle. It will have the exact same effect.
Old Sep 25, 2004 | 09:15 AM
Larry's Avatar
Do you race at part throttle. Wide open throttle is all that matters to me.
Old Sep 26, 2004 | 02:58 PM
That statement was pertaining to what was said about factory cars benefiting from something as large as a 90mm setup.
You do not mash your pedal all the way to the floor off the line. If you do, you obviously don't know what you're doing. As the engine speeds up, your foot should get heavier. Obviously quick-like, but that's how you work the throttle. No matter what you're on, track, or street. @ ALL throttle positions, a larger unit would be an advantage, period.
Even on a factory intake. Anything over 80mm may be useless there, but it's definitely better than 75mm.
I don't know...that would mean the throttle is more touchy, so in reality you would have less control over the throttle in exchange for "throttle response".
Old Sep 27, 2004 | 06:55 AM
Larry's Avatar
I must be doing something wrong because I hit my throttle as quickly as I can and all the way to the floor from zero at the track. Something is wrong if you are not nailing it from zero!
Old Sep 27, 2004 | 04:43 PM
Full-Force's Avatar
i might try that bullchit with stock tires but with sticky tires im going ***** 2 the wall WOT from the hit!
Old Sep 28, 2004 | 03:07 AM
TRAGIC's Avatar
Thats the first i've heard of this technique. I assume you are alot faster than 12's. But for us slower cars... full thorttle all the time works best at the track.
Old Sep 28, 2004 | 04:05 PM
mike c.'s Avatar
t.n.t is making a ring to fit the fast intake 90mm th-body,so looks like i'll be buying that.
Old Sep 28, 2004 | 06:39 PM
Worm's Avatar
A ported one would probably make the same or more HP and would cost 1/3 as much.
Old Sep 29, 2004 | 11:53 AM
Flawless02SS's Avatar
Mike, the stock TB can handle up 600hp
