SLP Lid Rubbing
Old Sep 26, 2004 | 11:21 PM
CMKworm's Avatar
Default SLP Lid Rubbing
I have an slp lid and it has rubbed paint off my hood. What should I do?
Old Sep 26, 2004 | 11:50 PM
Gloveperson's Avatar
Try to re-adjust the bellows to make the lid move a little farther into the car. I have the SLP Lid and I don't seem to have the problem, although I have heard of it before.
-Todd
Old Sep 27, 2004 | 12:24 AM
16nrollininaws6's Avatar
Originally Posted by CMKworm
What should I do?
Get nice and drunk then get in a fight with the lid. It will learn its damn lesson.
Seriously though, maybe just get a new lid.
Old Sep 27, 2004 | 01:03 AM
WS6freak's Avatar
I have the same problem, I'm ditching the lid and getting the Volant CAI.
Old Sep 27, 2004 | 04:03 AM
DaddySS's Avatar
If you have CAI, it makes it more difficult to adjust. As said above, you need to get it further back and all it takes is about 1/8 to 1/4 inch lower and you be good. Get some black touch up for the hood or put a sticker over it!
Old Sep 27, 2004 | 11:52 AM
LSV1970's Avatar
I stick a very thin black rubber-foam on the black hood and troubles are over.
Old Sep 27, 2004 | 12:02 PM
JarredWS6's Avatar
i have the slp lid and have the same problem. fitment on those lids is terrible.
Old Sep 27, 2004 | 12:32 PM
2MuchRiceMakesMeSick's Avatar
My SLP lid did the same problem. Another vote for to get in a fight with it
Old Sep 27, 2004 | 07:23 PM
NateLS1's Avatar
I have the SLP Lid, and the 2 clamps that hold it down never stay closed! Every time I pop the hood they have popped off....I adjusted the couplers and I still have the same damn problem.
Old Sep 27, 2004 | 09:35 PM
02WS6Bird's Avatar
it seems difficult to see how you other WS6 guys have an issue?...did yall tuck in the front lip of the lid behind the notch on the airbox or is it hanging over the end?my buddy's Z was hangin over...didnt want to clamp shut oso i set it up like mine....no issues (HES GOT THAT DAMN SLP MAF!!!! I HATE THAT THING! it makes everything difficult)
Old Sep 27, 2004 | 11:02 PM
SLP LS1's Avatar
Buy the Donaldson Blackwing, expensive, but no rubbing! Similar hp gains!!! I hear this from a lot of people. I will be buying one soon!
Old Sep 28, 2004 | 12:12 AM
WS6freak's Avatar
1) Untighten all clamps (lid->maf, maf->bellow and bellow->TB)
2) Unlatch the clips
3) Pull the lid just a little bit towards you, just so the tabs on the back get off
4) Put the lid back holding the front part slightly up, making sure the tabs go under
5) Press the lid towards the MAF
6) Press the lid down, making sure the lip between the metal clips is INSIDE the box
7) Latch the clips (they should latch good now, and stay there)
8) Re-tighten all clamps again
9) Done -- no more rubbing on hood, no more unlatching clips.
Old Sep 28, 2004 | 06:25 AM
02WS6Bird's Avatar
inside what box? do you mean the lid?...i have that lip hoding my lid on ther dont kno bout any of you other guys...i really dont think it makes amuch a differecne if at all....sealed better i thought...
Old Sep 28, 2004 | 12:32 PM
NateLS1's Avatar
i have the SLP MAF as well, maybe thats my problem
Old Sep 28, 2004 | 12:45 PM
SScreaminDemon's Avatar
i've got the SLP MAF w/ the SLP Lid. i've never had any problems. the only thing is just making sure the middle of the lip is tucked in.
Old Sep 29, 2004 | 02:18 AM
Yes, about 85% of your lid goes inside that lip, the other 15% (the corners) go outside. That cleared up the issue for me
Old Sep 29, 2004 | 09:31 AM
67SS&99SS's Avatar
I had the problem of the clips popping everytime i opened the hood, then I put the middle part of the lid inside the airbox and the corners on the outside and I have yet to have any more problems. I also have the smooth bellows, but I don't have the slp maf sensor.
Old Sep 29, 2004 | 09:39 AM
ChiefBrody's Avatar
I had the same problem. I ended up fileing and sanding the bottom of the lid towards the rear if the lid. Took a long time, just removed a little bit at a time, but I finally got the lid to stop rubbing. It also closed up a small gap between the lid and lower box.
Old Sep 29, 2004 | 09:46 AM
JackZ28's Avatar
I'll sacrifice the slight rubbing for the best flowing lid. GMHTP did a test, and out of 10 lids the SLP lid flowed best!
