LS6 intake modification?
Old Sep 30, 2004 | 03:14 AM
OnyxY2KSS's Avatar
Default LS6 intake modification?
ok so my ls6 has been sitting in my room collecting dust for the past month because the coolant lines i ordered have not been shiped yet...
i just searched for about 30 min for alternative routes to take and found a couple of posts on grinding the bottom of the intake with a dremel, who has done this and would you reccomend it?, anyone have any pics or advice for me???
Old Sep 30, 2004 | 10:25 AM
LS1LT1's Avatar
Lightbulb
I like this method/option better I think:
http://www.ls1howto.com/index.php?ar...e1b3bcc94d1a06
In other words you can modify your current pipe to work as well.
Old Oct 1, 2004 | 12:36 PM
8banger's Avatar
That's what I did with mine. Works beautifully, just make sure you get solid welds on the rear coolant plugs.
Old Oct 1, 2004 | 01:21 PM
2001CamaroGuy's Avatar
they are stainless right?
Old Oct 1, 2004 | 01:23 PM
under_construction's Avatar
I have a couple of brand new rear LS6 plugs laying around - pm me if you can use them. That should make it easy to cut the existing lines to use on the front.
Old Oct 1, 2004 | 01:24 PM
LS1LT1's Avatar
I think so, or maybe just chromed mild steel?
