TSP new catted Y-pipe
Overall, the thing fits very well. I was very surprised. The heat shield on the driver's cat is a little close to the fuel lines and the torque arm. As a matter of fact, after driving it a little, my torque arm has already made the necessary "adjustments" to the heat shield to get it to clear. I still need to ask TSP what they think about the fuel lines. But it doesn't bang or rub anywhere else. I did need to put some heater hose tape on the passenger heat shield because the shield looked like it would bang the header (Pacesetter) if I didn't. I did lose a little ground clearance, but I expected that.
By the way, I didn't get any instructions or markings either, but Jason described it to me over the phone and the picture on the first page looks correct.
Driver's side
Passenger's side
Side view
Under car
I think the Lakewood may not have cleared the stock y. Since this one hangs down lower, it should be no problem (assuming that was the reason
) The Best V8 Stories One Small Block at Time
I'd be interested to see someone pass a smog test with this Y-pipe.
I know it should be ok but I have heard of cars with aftermarket cats failing.
So far, I have not noticed any banging (and I have definitely run it hard
). The two places I mentioned before (passenger heat shield and torque arm) would be the ONLY two possibilities for rubbing/banging. I modified the heat shield some to minimize it banging on the header. It clears the y-pipe. And it looks like after going over a few railroad tracks that the torque arm has already made the necessary "adjustments" to the cat heat shield for me.I plan to get it up on a lift this weekend to re-check header bolts and fix some minor exhaust leaks, and I'll snap some better pictures while I'm there. I'll get some that show how much my SFCs clear. They're not DDs, but more like single diamonds. The only difference between mine and DDs is mine do not have the 3rd (rear) cross-brace going to the tunnel brace. I would think the fronts would be the same. Or at least so similar it would be scary.
I'll post in here when I get the new pictures.
I guess the cats flow pretty well if it's throwing codes
ALL TSP exhaust components are on special next week
Jason
Co-Owner, Texas Speed & Performance, Ltd.
2005 Twin Turbo C6
404cid Stroker, 67mm Twins
994rwhp/902lb ft @ 22 psi (mustang dyno) www.Texas-Speed.com
