Kook Headers are installed
Old Oct 11, 2004 | 10:33 PM
psykoTA's Avatar
Originally Posted by camaro99z
There are no provisions for the rear O2's on the y-pipe. Just get some O2 sims or have the sensors deleted with LS1 edit.
What kind of cats are they?
Old Oct 12, 2004 | 12:17 AM
Toadman's Avatar
I stooped by the shop today and asked the owner how they bolted on. He told me that the meachanic that did my headers did 4 LS1s before. It took him 8 hrs and the headers fit better then the other ones that he did but still he had some problems. Also I recieved in one post that I should change the maf air flow. Where do I buy the device to do it and is it hard to do by yourself?
Old Oct 12, 2004 | 12:21 AM
psykoTA's Avatar
Why would you need to mess with the MAF? I know LT's make the car rich, is that what is messed with when you get a "tune"?
http://www.ramchargers.com/cgi-bin/n...890&cat2=26891
oh BTW thanks for checking about the fitment, I guess its dif. for all cars....
Old Oct 12, 2004 | 12:39 AM
Toadman's Avatar
Thanks for the link. The car ran a little rich before I added the headers but now I can smell the fumes really bad when I'm behind the exhaust. I'm not sure about the tune thing either. I either need to cut some of the gas flow or add more air I guess.
Old Oct 13, 2004 | 12:39 AM
Toadman's Avatar
Today I when I started the car the SES light came on. Would it be from an O2 sensor and would that be the cause of my mpg decreasing? Th car seems to run the the as when the headers were installed.
Old Oct 13, 2004 | 12:43 AM
psykoTA's Avatar
If you can smell the fumes, it is probably a rich code. Everyone, how does the MAFT translator work? do you plug it in and forget about it? or do you plug in and adjust?
Why do the cars run richer with LT's? Is it because of the scavenging of the cylinder?
Old Oct 13, 2004 | 01:08 AM
LS1LT1's Avatar
Lightbulb
There are adjustments to be made and it can help but it's still best to just skip the MAFT and put that cash towards a real dyno tune/LS1 Edit.
Old Oct 13, 2004 | 01:22 AM
psykoTA's Avatar
When getting the car tuned, is it difficult to get the A/F ratio back to 14.7:1?
 Michael S. Palmer
Old Oct 13, 2004 | 01:28 AM
LS1LT1's Avatar
It can be dependent on some of the components/parts/mods chosen but in most cases no, it's not too difficult as long as the tuner knows what they're doing.
Old Oct 13, 2004 | 01:32 AM
psykoTA's Avatar
Ok thanks. Well your in NJ, anyone you would recommend?
Old Oct 13, 2004 | 01:35 AM
LS1LT1's Avatar
Thumbs up
Yes, Cartek in Garwood, NJ ( www.cartek.net ) but that's a bit of a hike for you, worth the trip though.
Old Oct 13, 2004 | 01:42 AM
  #32
psykoTA's Avatar
Cool, thanks. Finally someone can recommend a place!! How about getting some SFC's welded in?
Old Oct 13, 2004 | 03:14 AM
  #33
LS1LT1's Avatar
Thumbs up
Yes they do it all there, specialists in all facets of LS1/LS6/LS2/LT1 performance for F-bodies, Corvettes, trucks, GTOs and even CTS-Vs.
Old Oct 13, 2004 | 09:58 AM
  #34
camaro99z's Avatar
They are Carsound cats.
Old Oct 13, 2004 | 11:42 AM
  #35
HumpinSS's Avatar
The car wont deviate from 14.7 while in closed loop. The smell is prolly because of no cats and running a little richer (switching to maintain 14.7) A quick tune will help this rich condition and really is nothing to worry about
Old Oct 15, 2004 | 12:05 AM
  #36
Toadman's Avatar
Theres no actual dyno tuning places that I know of in the area. The shop where I got the headers on at said about using the predator or hypertech tuner. I am not sure if they know how to use LS1 edit. Which is the best tuner to use without dynoing the car and easy to understand?
Old Oct 15, 2004 | 12:23 AM
  #37
LS1LT1's Avatar
While the true LS1 Edit or HP Tuners dyno tune is ideal and WAY better than any 'handheld' tuner, I would get the Predator over the Hypertech if forced to choose one of them.
There is also the Superchips Microtuner, Crane and Vinci models as well.
Old Oct 19, 2004 | 03:56 PM
  #38
Toadman's Avatar
The SES light went off today. Did the computer have to recalibrate and is that caused the light to turn off?
Old Oct 19, 2004 | 07:36 PM
  #39
mrr23's Avatar
http://www.stealthram.com/vhptuner.htm here's a tutorial i made about the VHP tuner. i use it. i gained .2 and 1.4 mph on my 00 formy. only mods at time were the airlid and cutout.
Old Oct 20, 2004 | 10:21 PM
  #40
Toadman's Avatar
Did you run the car with the cutout and lid first? Then you programmed it and the car ran .2 and 1.4mph faster? Thanks for the info.
