Idle is high after TB install
Something wrong?
Something wrong?Brandon
to seat it, and that you do not see daylight past the
blade when closed ("lumpy" daylight would mean the
port-job munged the seating circle). But I think that
"cruise control" more likely means vacuum leak (check
the TB-manifold O-ring), overdrilled hole, cables too
tight (hanging the TB slightly open) of crap in the IAC
that keeps it from seating. Seems to be a high incidence
of plain bad IAC motors when dealing with the fancy
powder-coated "professional" TBs. Might swap your
old IAC servo on after blowing out the IAC bore and
checking the seating circle for crud.
tight (hanging the TB slightly open) or crap in the IAC
I bored hundreds of units for all makes and models a couple yrs back. Every now and again, one would slip through the seat test. Just one of those hard to 'see' details.
I got everything worked out though. One and a half turns got me around 600RPMs again for idle. Had to reset the PCM fuse though to ditch the code. Thanks for all the help guys!
