Need Help Wiring o2 wires
Old Oct 17, 2004 | 09:58 AM
98Blubrd's Avatar
Default Need Help Wiring o2 wires
I have jet hots and i have never really figured a good way to wire the driver side o2. i burnt one wire before. as of right now i have zip ties to pull the drivers side wire under the transmission and connect to the passanger side wire just to keep it from the header on the drivers side. I have the the corvette o2 sensors which are a lot longer than the stock ones so wire length is not a problem. HOW DO YOU HUYS HAVE YOUR DRIVERS SIDE O2 WIRE WIRED UP? Post pics if possible. Thanks.
Old Oct 17, 2004 | 07:31 PM
98Blubrd's Avatar
come on guys? I know plenty of you have longtubes. I know its a stupid questions but i need some help. Please Help Me out here.
Old Oct 19, 2004 | 05:04 PM
WILWAXU's Avatar
Need to find something to zip tie it to away from the header.
Old Oct 20, 2004 | 08:37 AM
98Blubrd's Avatar
They are sip tied like i described but is kinda just ghetto looking. there really isnt anything in the drivers side to zip tie is to. the o2 on the drivers side is located on the inside. so the only thing would be the block itself or transmission which get pretty hot also. THe oil filter is in the way aslo. Cant anyone with Jet Hots give me some info.
Old Nov 7, 2004 | 11:59 AM
bradl1982's Avatar
I would also like to know what you guys did wioth yours. Mine are just hanging down. My idea is to get some metal wire to hold them to something. I think zip ties would melt. What should I connect them to that doesn't get that hot?
