Is There A Difference Between The Ls1 And Ls6 Throttle Bodies?
Old Oct 17, 2004 | 11:43 PM
IMD's Avatar
IMD
Default Is There A Difference Between The Ls1 And Ls6 Throttle Bodies?
are they both 75mm?
thanks.
(yes i searched dammit!)
Old Oct 18, 2004 | 12:01 AM
LSUxBlake's Avatar
Both 75.
Old Oct 18, 2004 | 08:40 AM
jimmyblue's Avatar
Moderator
LS6 was only found in the 'vettes and these were the
"drive by wire" TB. You don't want that for an F-body.
But, the LS6 manifolds that came on F-bodies and 'vettes
will work with the F-body and truck TB (though the truck
throttle cam is more like the early years F-body, and
that changed about 2000 to a bigger one). You can swap
shafts though.
