HELP PLZ! Think I broke something
Old Oct 21, 2004 | 08:22 PM
Revelation222's Avatar
Default HELP PLZ! Think I broke something
I was doing my LS6 intake swap, and I think I snapped off the knock sensor behind the intake. It is black cyilindrical plastic peice with a green quick connect going to it. Is it what i think it is? I heard in passing to be careful of it, so I though I was being careful, but by the time the intake was out of the way, I saw that it was broken.
Now, I need to know what I need to do in order to fix it. Possibly a part number from GM. Do they normally carry them in stock? It looks to screw into the block, so do I need to do anything special to get a new one in there. I take it that I cant put the new intake on until I get this fixed, so please someone help me with some info as soon as possible.
Nothing is ever easy.
Old Oct 21, 2004 | 08:26 PM
DrkPhx's Avatar
Sounds like the oil sending unit. Your local GM dealer should have it.
Old Oct 21, 2004 | 08:33 PM
Oh ok, are they expensive? Do I have to do anything special when re-installing it? Thanks for the help.
Old Oct 21, 2004 | 08:37 PM
MM98's Avatar
They're not cheap... I think they list for $30, part#12559781... You also need a special socket to remove & install it.
Old Oct 21, 2004 | 09:09 PM
DO they sell the socket as well?
Old Oct 21, 2004 | 09:24 PM
MM98's Avatar
Most dealers do not sell tools, so probably not... Any parts store should carry them though(Oreiley's,Autozone,Napa etc..)
Mike
Old Oct 21, 2004 | 09:26 PM
Mike
You said it was a "special" socket. Any idea what they would call it?
Old Oct 21, 2004 | 09:35 PM
MM98's Avatar
Probably be labled "GM oil sender socket" or something like that, not really sure... I broke my as well when doing the swap & fortunatley it was at work in the service dept.. Luckily my buddy, who is a tech, had one.. I ask him & that's where he said you could get them... Good luck with it.
Mike.
Old Oct 21, 2004 | 09:58 PM
Toonz's Avatar
That is actually your "Oil Pressure Sensor" if you're refering to #2 in the diagram I attached... it needs to be torqued to 15 ft lbs so if you use a crecent wrench or open ended wrench and get it pretty snug it will be good enough.
Old Oct 21, 2004 | 10:11 PM
jrp's Avatar
jrp
SN95 Director
i knew what you broke just by the title . should of asked me to come up, i would of helped you or told you to be wary not to break the oil pressure sending unit. you have to becareful the brake booster line doesnt snag it up.
Old Oct 21, 2004 | 10:44 PM
Toonz's Avatar
That's ok... one of the guys here broke his, then he broke the oil level sensor as well... 2 for 2, only a few more to go.
It is a pretty common occurance.
Old Oct 21, 2004 | 11:03 PM
Toonz's Avatar
98 Oil pressure sensor 12559781
99-02 Oil Pressure sensor 12562267
$32 at the dealer, can get it cheaper from that parts "other" website.
Old Oct 21, 2004 | 11:49 PM
Yeap thats exactly what did it, the brake booster line.
Thanks for the offer to help though. But I wouldnt want you to have to drive all the way up here for an intake install. I figured something that easy I couldnt mess up. (Guess I forgot who I was dealing with... Me hehe)
I thought I had it. Seemed easy enough LOL. I guess I never learned the word "Gentle" in school or something.
Ah well, ill get the thing worked out tomorrow.
Thanks Fellas.
Old Oct 21, 2004 | 11:51 PM
Thanks Fellas.
Oh **** no. I just saw your title under your name, J. LMFAO
Thats F-ing hilarious.
