Pullies cherping like birds!
dURING HTE LAST FEW MONTHS, HOWEVER, IT stopped squeeking. I don;t know why. A neighbor had the same issue and he replaced all the pulleys - no help, for him however.
If mine starts up again i will try the soap trick. Should i use Ivory, Irish Spring, or Dial Deoderant soap?
Then I found out about this :
GM had a technical service bulletin, TSB# 00-06-01-008 about the squeaking/chirping noise, caused by a slight belt-misalignment between the alternator and other pullies. Calls for changing the alt. bracket to GM# 12563327 and replacing the idler pulley with # 12563326.
I think the TSB was for '98-01 years, not sure though.
